Can I use the Factory ECM?
Old Oct 27, 2002 | 02:50 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
first of all this is what I have: 1987 Camaro TPI 5.7 with 700R4. I am planning on dropping a low compression 406ci engine I have sitting in my garage in it, as well as getting the new Holley StealthRam intake. Then, I plan on a turbo, or twin turbo (probably single turbo, the more I think about it). I'm planning 600-700hp and 50-60# injectors. Am I going to have to switch to DFI? Originally, I thought I would have to, but after reading posts, I believe I'm on the border line. What do you think? Thanks.
Ryan
Old Oct 31, 2002 | 12:11 PM
doesn't anyone know? or atleast have any opinions on this?
Old Nov 7, 2002 | 02:20 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
There were no factory TPI (V8) cars with
turbos/SCs, so getting the factory code to
work with a 2 or 3-bar MAP or going way
past the capabilities of the factory MAF is
difficult if not near impossible at those power
levels.. Additionally, injectors of that size
will require high current peak&hold injector
drivers that (again) didn't come in any multi-
port FI factory ECM..
HTH
mike
Old Nov 7, 2002 | 02:40 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Well.....it all depends..
Theres always the 749 from a SyTy.
To run P/H's tho the drivers will need to be swapped to handle the additional load. (It will run 4 P/H's stock, using the Sunbird Turbo wiring style)
Do a search on the 749.. lots of info
Old Nov 11, 2002 | 11:06 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Can I use the Factory ECM?
Ryan
50s tuned right will get you to 750 HP easily.
50s are saturated so your OK ecm wise for them.
You need to read thru a commented Hac to see how any one calibration works to see what you'll need to do.
Seems like it would be easiest to convert to a T/C type ecm like the syclones, and typhoons used.
gta892000
Aug 11, 2019 11:16 AM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
