730 ECM minimums
Old Nov 13, 2002 | 01:51 PM
John Manson's Avatar
730 ECM minimums
Does anyone know what the minimum connections are to make a 730 work in a 1991 5L TPI camaro? I have tested every wire at a dozen times and the injectors still won't fire! I would like to not connect anything that is not really required to get it to run. This is a 911 request! Thanks.
Old Nov 13, 2002 | 01:59 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
have you disabled VATS in the chip?
Old Nov 13, 2002 | 02:09 PM
No but I am re-using the vats module already in the car. I read about 2.5 volts on the vats wire when cranking which is good according to the GM service manual. The ECM has a new stock chip correct for this year car.
Old Nov 13, 2002 | 02:17 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
how about some info..
1 what are you swapping from. 165 to 730 i assume.
edit.. i see your going from tbi to tpi.
2. does the fuel pump prime when the key is turned?
3. how did you wire the ESC? remove the firewall mounted module and jump wires? or ??
4. you need most of the wires other than char cans,a.i.r., egr, A/C.
5. do you have a scan tool?
6. is the SES light on and fan running?
Old Nov 13, 2002 | 02:28 PM
YES
YES
Left it in place. The service manual schematic shows only 1 wire from the distributor modile connecting to the ECM.
OK.
NO.
SES and other dash lites good. Fan is not connected at this time.
__________________
80 Malibu Cpe
5.0 TPI/M90/SD/749 ECM/T-10/9"
<a complete frame off restification>
RAW Performance Engineering
http://turbotpi.homestead.com/MALIBUTPI.html
Old Nov 13, 2002 | 02:41 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Originally posted by John Manson
[B
__________________
80 Malibu Cpe
http://turbotpi.homestead.com/MALIBUTPI.html [/B]
This is probibly the problem. the 165 ECM had the ESC external of the memcal, the 730 moved the ESC to the memcal. there are 4 wires from the dist to the ECM.
Follow Mikes instructions on rewiring the ESC module need to jump a few wires and disconnect the firrewall mounted module.
Repinning table sorted by '165 order
'165 Harness '730 ECM
A1 (Fuel Pump Relay) BA11
A2 (AIR Valve - Port) GF2
A3 (Evap. Canister Purge) GF7
A4 (EGR Cntl) GE9
A5 (SES lamp) GE7
A6 (IGN +12v) BA6
A7 (TCC solenoid/A4) GF6 (Automatic Trans)
(Shift light/M5) GF1 (Manual Trans)
A8 (ALDL Serial Diag) BA8
A9 (ALDL Diag Term) GE12
A10 (VSS {buffered}) BC6 (requires PROM change: Mag VSS
at 0x18 b6 for $8D PROMS)
A11 (MAF Analog GND) N/C
A12 (Sys. GND) BA12
B1 (BATT +12V) BB1
B2 (Fuel Pump Signal) GE13
B3 (EST Ref Low) BD9
B4 N/C
B5 (Distributor Ref.) BD8
B6 (VATS) GF10
B7 (ESC Signal) GF9 (req new, direct fed knock sensor
or ESC jumper and resistor)
B8 (A/C Signal) BC9
B9 N/C
B10 (Park/Neutral Sw Signal) BD16
B11 N/C
B12 (MAF Signal) N/C
C1 (Fan Ctrl) GE8
C2 (AIR Valve - Converter) GF4
C3 (IAC "B" Low) GE6
C4 (IAC "B" Hi) GE5
C5 (IAC "A" Hi) GE3
C6 (IAC "A" Low) GE4
C7 N/C
C8 (4th gear switch) BD14
C9 N/C
C10 (CTS Signal) GE16
C11 N/C
C12 (MAT Signal) GF16
C13 (TPS Signal) GF13
C14 (TPS +5v ref.) BA5
C15 (EGR Diag) N/C
C16 (Battery) BC16
D1 (Sys GND) BD1
D2 (TPS,CTS,MAT GND) BB5
D3 (Sys GND) BD6
D4 (EST Ctrl) BC8
D5 (EST Bypass) BC7
D6 (O2 GND) GE15
D7 (O2 Signal) GE14
D8 N/C
D9 N/C
D10 (Sys GND) BD7
D11 (A/C Pressure Sw.) BD12
D12 (MAF Burn off) N/C
D13 N/C
D14 N/C
D15 (Injectors 1,3,5,7) BC11
D16 (Injectors 2,4,6,8) BC12
New sensor/wires needed to be added:
BA4 (MAP +5v ref.)
BB6 (MAP GND)
GF15 (MAP Signal)
These signals can be brought in thru the harness on the MAF
wiring if you build an adaptor cable or splice into your MAF harness
plug. You MUST wire the adaptor or splice this way or risk an electrical
short:
BA4 (MAP +5v ref.) MAF pin B (165 ecm pin A11)
BB6 (MAP GND) MAF pin A (165 ecm pin D1)
GF15 (MAP Signal) MAF pin C (165 ecm pin B12)
I was able to build a MAF-MAP adaptor plug by cutting the "female"
connector from a broken MAF, and soldering the connectors to a
"wire harness" that terminates on a MAP plug. (available at most
any Auto Store)
'730 ECM signals not connected
BC1 (VSS output 2000ppm)
BB9 (VSS Low)
BB10 (VSS Hi)
BB11 (VSS output 4000ppm)
Old Nov 13, 2002 | 02:53 PM
Thanks for the info. I will see how this compares to what I already have done. Since the car was a working TBI before we converted to TPI, it already has a MAP sensor. Are you talking about the module mounted on a bracket on the firewall near the windshield wiper motor? We have the same drawing as you included in the post so we already have the wires like this, I think. Do the 4-connector wires from the distributor first go to the firewall module before connecting to the ECM?
Old Nov 13, 2002 | 04:27 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
No, straight to the ECM. The ESC circuitry is the knock sensor. It now needs to be wired direct to the ECM, bypassing the old module on the firewall. Also the knock sensor needs to be changed to the 730 type, or IIRC a resistor (3.9K??) needs to be installed in series with the original sensor.
Old Nov 14, 2002 | 08:03 AM
Thanks. The 730 knock sensor is one of the new parts I purchased. Since the car has to pass emissions every 2 years, I changed what can't be reused from the TBI to GM TPI parts.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
