305---->350. need chip?
Old Sep 9, 2003 | 04:29 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
I have a 1984 Trans Am 305 HO (L69) with 700-R4 tranny with stock computer and chip. hopefully by winter, i will have a mild 350 in the car. Will i need to get an aftermarket chip for this, or will my stock one run fine? thanks for any help
Old Sep 10, 2003 | 11:42 PM
84 t/a 5.0's Avatar
come on guys, help me out
Old Sep 11, 2003 | 05:48 PM
Kevin Gray's Avatar
The chip makes the primaries go full rich at WOT. You can do adjustments to the rich stop to allow more fuel to the primaries (under WOT) and raise the Master control soloniod (lean stop) a little to richen up the leanest condition the engine would see. Depending on how much healthier the 350 is than the 305, you will need a new hanger and / or metering rods for the secondary that will add enough fuel under heavy and wide open throttle conditions. Again, depending on how much healthier the engine is, you might need to adjust the TPS.
There is a pretty good tuning tech on this site and at www.montecarloss.com on the computer controlled carbs. Between the two tech articles at these two sites, you should have enough info to be able to tune it in,,,, without the need for a chip.
Old Sep 12, 2003 | 03:33 AM
Z69's Avatar
Z69
There was/is a kit to put an HO350/ZZ3 into camaro's. It listed the carb parts required to get it to run and pass smog. Made about 300HP. Check with ScrogginDickey on it.
Old Sep 12, 2003 | 10:12 AM
84 t/a 5.0's Avatar
thanks a lot for the help guys
Old Sep 12, 2003 | 10:15 AM
84 t/a 5.0's Avatar
quick question, the computer controls the ignition, so do the 305 and 350 have the same firing order? I'm probably going to get a replacement distributor, is there a specific kind i should get, or will the direct replacement for a 305 work?
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
