ECM Code 12 constantly
Old Sep 19, 2003 | 11:20 AM
woodstoc's Avatar
Hi guys, newbie to the site, normally work on a 82 Crossfire Vette but my daughter has the following:
89 Camaro, 305 TBI.....Car was running fine other than occassional die from idle. It just stopped running on her in the driveway, will start for a second or so, then shut off. I was able to get it to run for about 60 seconds one time. Checked for codes and getting a constant 12. Not three 12's then a trouble, just constant 12's, one after another. I replaced the MAP, new plugs, wires, distributer and rotor, fuel filter.
It seems to have good fuel pressure and spark. Car has 127,000 miles, but good compression.
Any ideas? :hail:
Old Sep 19, 2003 | 07:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: ECM Code 12 constantly
Repeating 12s is just no distributor reference pulse, which is normal.
When cranking can you see the injectors spray some?.
All fuses good?.
If no fuel spray, see if there is power to the injectors. The ECM grounds the injectors to fire them.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
eustodp
Sep 20, 2015 05:09 PM
Reese-J
Sep 14, 2015 02:43 PM
RyanJB
Sep 2, 2015 01:27 PM
