Have 730 ECM, SD harness and ...TBI intake setup
Car: 89 IrocZ
Engine: L98-ish
Seems to me it should work, huh?
My thoughts are that TBI injectors are about 2ohms each, in parallel should be about 1ohm ..16 TPI injectors at 16-18ohms each, come out about the same.
Reason I want to run it this way is I stumbled across a complete TBI setup, minus harness and ECM (which I already have the above mentioned SD stuff).
Starting from a stock tune in the prom, do I have a chance?
Motor is basically stock (non-thirdgen) to be tweaked as needed/upgraded.
Thanks.
Thanks.
Car: An Ol Buick
Engine: Vsick
Re: Have 730 ECM, SD harness and ...TBI intake setup
The 749 ecm however has 2 injector drivers and is compatible with the dual TBI.
I have run a TBI with a 749, and it did work, but ran out of time for fully tuning it.
Be advised thou, that most any calibration you begin with for a 749 is for a TPI, which is a dry manifold, vs TBI which is wet, so you'll probably have to make some drastic AE changes.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
730..TBI
A 730 will not run a TBI ...I tried and could not make it work.
Just to save you a little time and trouble.
Car: 89 IrocZ
Engine: L98-ish
That's good info...I was trying to use up some stuff I've collected.
I guess ths old beast will just have to go with 8 injectors instead of two.
Car: check
Engine: check
Transmission: check
Re: 730..TBI
RBob.
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
