Possible computer problem
Old Oct 30, 2003 | 10:31 AM
Thirdgen86TA's Avatar
Last night by check engine light went on and it idled kind of funny. It wasn't real bad just a little higher. I have an aftermarket custom burnt chip also. Well I tried to pull a code with the paper clip and the light wouldn't flash. Then I used my scanner to get info out of the computer and it keeps saying NO DATA. Also the fan is always on when I have the key in the ON position. I am assuming this might have something to do with the computer or chip. I don't know much about electronics so if someone could give me ideas I would appreciate it.
Today I drove it to school and it started off really rough. I drove a few miles, pulled the computer down and pushed the chip down harder. Then I started the car and it acted normal. Drove a few miles and it started up with the problems again. Every time I would come to a stop it would die. I had to keep on holding the brake and the gas at the same time.
Old Oct 30, 2003 | 03:05 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Possible computer problem
Yep, sounds like the memcal socket's doa.
Not being able to flash a code is another indicator.
Old Nov 2, 2003 | 10:30 PM
Well I switched one of my chips and it is doing the same thing. Could something be wrong with the whole computer?
Old Nov 3, 2003 | 11:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Try tapping on the ECM while the engine is running. If the engine stumbles or misses and/or the SES light changes then the ECM is bad. The '165's are notorious for this.
RBob.
Old Nov 4, 2003 | 10:36 AM
Where would I pick up another computer and for about how much?
Old Nov 4, 2003 | 11:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You can try the classifieds here on TGO. The junkyards should also have one. The '165 was used in '86-'89 f-body's along with a bunch of trucks ('87-'89?). Priced between $25 - $50US.
RBob.
Old Nov 4, 2003 | 01:03 PM
Alright so it is definately the computer. I pulled the car out and let it run and I gave the computer a little knock and it kept stumbling.
I just have to get any computer between 86 and 89 and it will work? Even out of a camaro right?
Thanks for your help btw.
Old Nov 4, 2003 | 01:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Using your current MEMCAL any of the '165s will work. Even a truck '165 ECM. The part that defines the ECM as being for a particular vehicle is the MEMCAL.
RBob.
Old Nov 5, 2003 | 02:52 PM
So even a computer out of a v6 would work? All I would need to do is switch memcals?
Old Nov 5, 2003 | 07:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes.
RBob.
z28addict8490
Sep 5, 2015 03:56 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
perZ
Aug 15, 2015 01:17 PM
