Scanning / Datalogging
Old Nov 27, 2003 | 10:33 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
What all can be scanned/datalogged with available software on a 92 (L98) TPI car?
What all do I need to scan/datalog?
Old Nov 28, 2003 | 07:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Scanning / Datalogging
On a SD TPI setup there are a lot of items available through the ALDL port. A sampling is RPM, MPH, engine run time, coolant and plenum temperature, TCC info, EGR info, airflow, O2 reading, commanded AFR, etc.
If you have a laptop Moates has a free scan/dat alog software at: http://moates.net/gmecm/software.html
Look for the ECM852.ZIP download. You will need a cable to connect between the laptop & ALDL port.
Some commercial scan tools only allow scanning, no logging capability. Once that have logging include Ease and Diacom (that is not a recommendation for any commercial scan tool).
RBob.
Old Nov 28, 2003 | 09:37 AM
Car: 92Z28
Transmission: A4
Thanks for the help. I just have a couple of questions;
Where can I buy the interface cable?
Are the parts available and are they hard to make?
Old Nov 29, 2003 | 08:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check the link above (moates) there are several interface cable designs there. Parts are easy to get. Also lists some places to purchase cables.
See this link for additional information:
https://www.thirdgen.org/newdesign/tech/promintro.shtml
Lists scan tools, data loggers, cable info, prom info & equipment. . .
RBob.
1992Z28!
Nov 19, 2015 07:33 AM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
RGB2015
Sep 20, 2015 09:26 PM
bamaboy0323
Aug 15, 2015 07:20 AM
