Someone with easy access to their 7730 ECM- need a really big favor
Whoever is able to, could you go to ECM connector terminal A6 (the pink/black stripe wire), and with the ignition off and the connector removed from the ECM, take a ohmmeter measurement from that wire to the negative battery terminal? I'd really appreciate it. I'm reading 8.5 ohms on mine, and I'm wondering if that is normal? It's a slight short to ground, but I'm curious if it could be abnormal.
Thanks much in advance!
Car: check
Engine: check
Transmission: check
Re: Someone with easy access to their 7730 ECM- need a really big favor
Edit: A6 is also the ignition power feed on a '165 MAF setup.
RBob.
RBob,
Thanks. What's happening is that I believe my idle misfire is coming an excessively lean condition resulting from a damaged ECM- somehow shorted out. I had quite a few wires for systems that remain unused in my car, so I bundled them up in the engine compartment when I swapped the EFI into my '71. Thinking maybe a short circuit developed someplace, this weekend I went through and pulled the unused terminals out of the ECM connectors. I also did a voltage/continuity/ground check on the remaining terminals (ECM disconnected) and found this 8.5 ohm value on A6.
redformula88
Oct 14, 2015 06:08 PM
gta892000
Sep 16, 2015 12:37 AM
