'85 TPI ECM upgrade, "165" ECM only?
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Axle/Gears: 3.23 posi 10 bolt
Must I use the "1227165" ECM or will another such as a "1227169" from a '86 Monte SS work? Any idea? Thanks, Randy
Car: check
Engine: check
Transmission: check
Re: '85 TPI ECM upgrade, "165" ECM only?
These two ECMs support a V8 PFI engine. ALong with any required smog equipment. They are both viable upgrade paths.
RBob.
Car: An Ol Buick
Engine: Vsick
go to the DIY-PROM board and investigate the 1227730 or 730. It's the ecm used in the 90-91 v8 F Bods.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by KTMAC
I am looking to replace stock ECM(w/MAF) so that my 1985 IROC 305 EFI can be programmed and use the EDBt 2 port.
ANyone know data about doing that?
K Mc
K Mc
https://dynamicefi.com/EBL_Flash.php
- Rob
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
