Tricky problem with TPS and IAC at 1volt
Old Dec 25, 2003 | 04:13 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
The problem is that the car has a slight "miss" only when at a particular spot in the driving range. After doing many scans and writing down the data at that particular time during the miss, I noticed it always happened from .94v to 1.01v on the Throttle position sensor. It looks like the idle air control valve started to actually open more and causing a sudden lean condition. This was when the idle volts was set at .54 for the TPS. I adjusted the TPS higher to .7 volts and the problem is gone. Of course, I am having a tricky time getting the idle to calm down now. Can anyone shine some light on why this would be happening. It seems like the computer wants to open the IAC valve around the 1 volt reading for the TPS. Is this normal? What could be done differently to the prom to get rid of this? Any help would be appreciated. This has been a ongoing problem for years. The engine is a 388 with a MiniRam II and a middle of the road comp cam. Thanks guys.
Old Dec 26, 2003 | 09:17 AM
87_TA's Avatar
Greg,
Do you burn your own proms?
If not it would be a great time to start.
You will probably notice that Idle BLMs are pretty lean 140s or higher? Usualy fixing the lean condition at idle/ part throttle helps alot.
If you still have the bog then you will want to work on the Acceleration Enrichment. Usually lowering the (Minimum delta TPS) in your constants helps alot.
But before you perform these steps adjust the IAC and TPS correctly.
Close or open throttle blades until your IAC reads 10 to 40 counts at idle in gear. (shuting car off between changes)
Then re adjust the tps to .5 - .6 volts.
Old Dec 26, 2003 | 09:32 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Do what he said, the cleaner u get your car idling and the closer to 128 at idle(in my experience) the cleaner it idles number 1, and number 2 the easier time u have leaving idle and also coming back down to idle from a stop. To do any of this u need to be pretty close on you tune and have your IAC clean and set correctly :-) Going thu the same thing currently had my idle base set high to cover idle tuning issues and working them all down together and currently have almost smooth 675rpm idle with a lt4 hotcam warm and in gear
LAter
Jeremy
Old Dec 26, 2003 | 02:55 PM
Greg's Avatar
This prom I did not burn(it was done when the car was on a dyno). I have not done it before, of course it is something I want to do but have not bought the equipment yet or have the knowledge. Right now, the IAC is 35-50 steps at idle and the BLM's are about 114. The integrator is at 128 at idle. I don't know enough to know why those would ever be different.
The person who tuned the car said that I was all right as long as the TPS was adjusted to under one volt at idle. Now, this always caught me off guard and I would adjust it to .54 because that is as I understand, correct. But at that .54 setting is of course when the car has this stumble once you put your foot into it at about 1 volt. I doesn't matter if I'm crusing or accelerating light. If there is any more then say one second of time spent in this TPS voltage spot the car has a quick sudden hesitation. The hesitation is coming from the MAF reading dropping in g/sec.
Old Dec 26, 2003 | 03:11 PM
3.8TransAM's Avatar
for my experience, i think 114 is still too rich for idle its in the realm of compensation for the ecm but i prefer close to 128 as possible(for my combo) 35-50 IAC counts hot in gear is alot more than i like to see ... I shoot for under 10 counts at idle in gear hot .....keeps theiac from messing with what your trying to do as much as possible.....
the other issues u have sound like a tip in stumble or hesitation to me............................
LAter
Jeremy
Old Dec 26, 2003 | 06:06 PM
87_TA's Avatar
114 Is on the rich side but nothing to sweat over , But if you have the equipment then fix it.
it sounds like you need to lower the (Minimum delta TPS) that should help alot.
Old Dec 26, 2003 | 06:37 PM
Greg's Avatar
I'd love to lower the TPS volts but then that is where the hesitation comes into play. If I lower the TPS any lower than .7 volts at idle then the there is the hesitation around 1 volts at moderate acceleration. Could this have something to do with the maf tables? I know for sure the hesitation is a sudden lean hesitation.
Old Dec 26, 2003 | 06:48 PM
Greg's Avatar
I should have put this in the last post but at WOT my O2 sensor is showing 840mv. I heard this should be 850-900mv, is this right. But in order to keep the 840 I'm running 50 psi on the fuel pressure. I'd like to lower that. Is this best done by adusting the maf table? And how would that affect the idle situation?
Old Dec 26, 2003 | 08:00 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Transferring to the appropriate forum ... this is not DIY-PROM related since you don't program your own PROMs.
Tim
Old Dec 26, 2003 | 08:15 PM
Greg's Avatar
I was going to make the appropriate changes though once I figure out what to change. Thanks for the help.
Old Dec 26, 2003 | 09:35 PM
87_TA's Avatar
Tim
That makes no sense
He said this in the first post!
[/B]What could be done differently to the prom to get rid of this? Any help would be appreciated. This has been a ongoing problem for years. The engine is a 388 with a MiniRam II and a middle of the road comp cam. Thanks guys.[/B]
Old Dec 27, 2003 | 09:00 AM
Greg's Avatar
Ya I hear ya bro. I guess you have to all ready know what you are doing with proms before posting in the prom board.
Old Dec 27, 2003 | 09:17 AM
TRAXION's Avatar
Originally posted by 87_TA
That makes no sense
What is your point Tom?????? It's not DIY-PROM related so it got moved. What's your beef?
Tim
Old Dec 27, 2003 | 11:57 AM
87_TA's Avatar
Tim
Sorry Tim,
No beef... I just thought it was being aimed to prom burning.
Not trying stir anything up. I just thought it was legit.
He asked what to be changed in prom and said he wants to do so.
I told him what tables I thought would benifit him to change.
Sorry again
Old Dec 27, 2003 | 01:18 PM
Greg's Avatar
Well, the question still stands. What should I change on the prom first? I'll be receiving the equipment soon. I lowered the fuel pressure down from the 50 to 44psi. The idle blms are a little better but still in that rich ball park of 114-119. At WOT the oxygen sensor is showing 804mv. Is 804 mv all right for WOT?
Old Dec 27, 2003 | 03:08 PM
87_TA's Avatar
Good change,
Well as mentioned above you will need to lower the delta tps to enable acceleration enrichment.
especially if you continue to get blm closer to stoich you will probably get more tip in hesitation.
If the rest of your part throttle driving range is a little rich I would make an inj. constants change to get closer, then if idle is still rich scale the MAF table.
806 is a little on the leaner side and will get leaner as you raise constants and/or lower FP.
For that you will probably want to raise the % change fuel/air adder vs. coolant temp.
Get the prom burning equipment and we will walk you through the previous and rest.
Old Dec 27, 2003 | 06:50 PM
Greg's Avatar
Wow, thanks for the help. It is starting to come together now. When I get this prom on the "programmer", will it tell me what the delta TPS is set to right now? Should I change that to the normal .54 or is that just what stock is and doesn't really matter? I would assume you set the TPS sensor to the same voltage as what you program the delta TPS to in the prom, right?
As for the driving range it actually is hanging around 128 - 123 blms most of the time until you get up into the higher 3500 + rpm range which like you said looks like could use more fuel.
I'm hoping that the delta tps setting is what is wrong. I've had this problem ever since I put the miniram intake on three years ago!
Old Dec 27, 2003 | 07:15 PM
87_TA's Avatar
Actaully the delta TPS is not in volts but in percentage rather.
currently the ARAP bin is set to 3.9 %.
Delta means change, so change in throttle position before adding pump shot.
But yes reset volts to .54 - .6 along with IAC counts on the car itself.
Buy the burner, buy tunercat or one of these great free programs. and you are set. you may need to buy a new prom or 2 they are $4 or so from craig moates and you can reburn over them 1000 times and do not need an eraser.
Read Traxions prom burning article and you are set.
Old Dec 28, 2003 | 12:54 PM
Greg's Avatar
I thought the Delta just meant the idle position for the TPS. But I know what you mean now. I've read the article about what to do and what is needed. I have the memcal which I'm a little confused on what to do there. I understand how the prom is in the memcal and all that, I just am not sure what to get other then the programmer from Xtronics.
Old Dec 28, 2003 | 07:12 PM
87_TA's Avatar
Well you have to understand that the programmer is nothing more than a tool to change hex address in your prom.
And proms are used for much more than auto mobiles.
By looking at the contents of a prom you would never understand it or what it means (atleast I would not) But I know that the smartest guy in the world Rrob could - and I mean that in a serious manner. That dude knows code like no tommorow.
But anyway you need an editing program that changes that confusing stuff into terms that we can understand and apply them to the prom.
So the editing software IE: Tunercat,Craig Moates freeware which is awsome! alllows you to see nice tables that say blah,blah,blah in car language and once a change is made it changes the cunfusing language in the bin file.
Which is all the prom burner knows is to burn that to the prom..
It could probably be explaned by someone smarter than me with this stuff. I am smart mechanically though
There are some guys here that need to stick to the things they know and not act like they know everything and you know nothing. Know what I mean LOL?
When in doubt you could always get the stuff and I could guide you through it like an awsome tuner did for me . Cudos to Drive it
AKA Pete.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
