Who is Running ACCEL PLUG'N'PLAY?
Old Apr 3, 2004 | 05:23 PM
nitrorocket's Avatar
Car: 71 Chevelle
Engine: 427
Transmission: T400
I am trying to find somebody running the ACCEL GEN 7 DFI PLUG'N'PLAY. I need someone to send me the fuel and ignition starting screen maps. Anyone?? My car does not start real well I am hoping to be able to copy somebodys settings for the start up sessions.
Old Apr 3, 2004 | 05:53 PM
biggtime's Avatar
Plug and Play??? You can make your own startup program on the DFIV7.
Old Apr 3, 2004 | 07:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The Accel Plug-and-Play systems are designed for specific crate engines. Accel provides all the tuning ready to go. It also includes the EFI hardware such as intake, TB and injectors. It is a bolt-it-together and turn the key system.
nitrorocket, not sure how this would work into the scheme of things for what you are asking.
RBob.
Old Apr 4, 2004 | 04:26 PM
Car: 71 Chevelle
Engine: 427
Transmission: T400
My car runs great! I have tuned it at the track and it idles excellent. My problem is when I start it cold, I have to crank it for a while and then it starts and then dies unless I really play with the gas pedal. I have screwed around trying to fix it. I have richened it up to the point that it bellows black smoke at startup, and I have leaned it out to the point it does not want to start. I want to see somebody elses setup that starts great and see where I am going wrong. I figured the PLUG'N'PLAY for the ZZ502 would get me real close to where I need to be. Accel should start a swapping board where people can trade data and settings.
Old Apr 6, 2004 | 06:09 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
With the key on, but engine off, look at the your operating point in both the Base Volumetric Efficiency and Target Air-to-Fuel Ratio tables. The amount of cranking fuel is set initially by the VE and A:F numbers in those tables, then modified by your Starting Fuel Coefficient graph. Increase the Starting Fuel Coefficient and try richening up the a:f and raising the ve numbers somewhat in the area that you are cranking in to throw some more fuel at it. If that doesn't help, see the atttached file -- (edit... issues attaching the file).
Old Apr 8, 2004 | 12:44 PM
Car: 71 Chevelle
Engine: 427
Transmission: T400
Well I called Accel and they sent me the ZZ502 program through E-mail. I loaded all the ignition, fuel, and idle maps and the car still did not start real fast. It died 4 times before it finally stayed running. The good part is that it used to idle real rich at startup and now it does not. It idles pretty clean at my 1100 rpm idle. What chart is CRANKING fuel only? I need to basically give it a big shot of fuel BEFORE it starts to get it running.
Old Apr 9, 2004 | 02:32 PM
aDFIguy's Avatar
Car: GTP
Engine: L67
There is no true cranking fuel table. The cranking pulse width is determined by the values in your VE and Target A:F ratio tables. When you are cranking, those numbers are combined with your Starting Fuel Coefficent to create a cranking pulse width. Raising VE and Starting Fuel Coefficient, and lowering the Target A:F ratio will give more cranking fuel.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Sep 2, 2020 07:13 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
