series/parallel injector wiring
Old Apr 9, 2004 | 09:06 AM
GoSlash27's Avatar
Car: '91 Firebird
Engine: TBI 305
Transmission: TH700
has anyone ever tried to wire injectors in series/parallel and see if they still open?
I know the consensus is that it wouldn't, but has anyone tried it?
After looking at this:
https://www.thirdgen.org/techbb2/sho...injector+drive
It occurs to me that it might not be impossible
(edit) going from 4ohms (stock) up to 12 ohms (hi flow saturated wired in series/parallel) might be a little silly....1/3 the power available to open the injectors.
Probably still open fine, but slow to respond.
Don't mind me, just thinking out loud (end edit)
Old Apr 10, 2004 | 12:02 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: series/parallel injector wiring
I've run TBI injectors in series/parallel, and at about 3K TPM, they started chattering in a erratic counding manner. Below that and above it they seemed to be firing OK. Some have run them that way, and are happy with them, but no one that I know of was really pushing them.
Just from the sounds of them, I wouldn't. It's the same sort of noise you get when your approaching static with a normal set up.
Street Lethal
Apr 30, 2019 12:14 PM
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Bryan F
Aug 18, 2015 02:28 PM
