ESC or distributor problem?
Old May 28, 2004 | 12:34 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I am having trouble getting my car to carry as much timing at idle as it is programmed to. I get very little differance when I unhook the ESC wire on the timing (less than 5 degrees) and it idles best at 28-30 degrees at idle and is programmed to do so. It shows 28-30 degrees on the datamaster scan logs but it isn't seeing it with the timing light. Anyone have any ideas?
P.S. Base timing is set at 6* BTDC
Old May 29, 2004 | 06:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ESC or distributor problem?
If this is your '92 with the stock ECM. . . After the EST wire has been disconnected and then reconnected the ignition needs to be off for a minimum of 10 seconds before restarting the engine.
If that has been done and the advance still doesn't come back then it is possible the ignition module is bad. If it is a wiring problem most of the time the SES light will stay on.
RBob.
Old May 29, 2004 | 08:30 AM
Car: 92Z28
Transmission: A4
Thanks RBob, I'll check it today and post.
Old May 29, 2004 | 10:02 PM
Car: 92Z28
Transmission: A4
Thank RBob. The module fixed it.
Old May 30, 2004 | 06:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
RBob.
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
