do OBDII cars use same aldl port?
Old Aug 29, 2004 | 01:59 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I was wondering, cause if you were to swap in a 96 and up engine you would have to swap that scanner port too right? if they are the same aldl ports as OBDI what programs are out there for lap tops? I mean my lap top is way more powerful then one of those hypertech programmers so it would only seem resonable that I could do similar things with it.
Old Aug 30, 2004 | 12:03 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Yes, OBDII ALDL ports are different.
Yes, there are OBDII scanning & tuning software programs available. Be aware that none are cheap.
Yes, the laptop-based stuff beats the HPP by a mile.
If you're talking about the LT1/LT4 engines specifically, IMHO a much better option is simply to use a '94-'95 OBDI PCM in place of the '96+ OBDII box. It's a very simple conversion, and the '8051 OBDI PCMs have more options available for scanning and tuning. (I'd recommend Freescan or DataMaster for scanning, and TunerCat with the $EE def for tuning)
HTH,
Old Sep 2, 2004 | 11:00 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I bought my 95Z28 with a 96 LT1 motor in it. It came with an OBDll ecm. I since switched it to an OBDl for tuning purposes. I am buying tunercat for it from Craig Moates.
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
89-S-dime
Aug 12, 2015 11:57 AM
mx127
Aug 10, 2015 08:13 AM
92projectcamaro
Aug 6, 2015 01:20 PM
