VSS - conversion to non-ecm power train
Old Aug 10, 2005 | 01:13 PM
kaptinkafeen's Avatar
My '91Z had been converted to a carb/HEI set up, and most of the ECM hardware has been removed from the car.
Speedo now does not work. The VSS sensor is still on the tranny (t5) however I do not even know where to start to convert the signal to something the Speedo can read without the ECM... It seems that the conector/wire harness to the VSS has been removed as well.
Someone mentioned that there is a conversion kit available for such an application, but he wasn't able to give me datails.
Any info would be appreciated.
-Andrew
Old Aug 10, 2005 | 03:47 PM
EdgesZ28's Avatar
Car: 91 GTA - 94 TPI Suburban
Dakota Digital SGI-5 Box should do the trick for you.
Ed www.edgesz28.com
Old Aug 10, 2005 | 09:44 PM
Ed,
Does the SGI act like the non-TPI equipped (TBI L03) VSS Buffer?
Is it easy to instal? Plug in, or?
Dose it have to be calibrated for a stock application, or can it be order for my specific application? Is it hard to calibrate?, especially since I don't even know what speed I am traveling at?
Andrew
Old Aug 15, 2005 | 09:11 PM
EdgesZ28's Avatar
Originally posted by kaptinkafeen
Ed,
Sorry for the late reply Andrew:
I cannot answer your first question, but I will say it has numerous combinations. There are various input and output settings, so I am sure it will work.
It is not hard to install. Wires just slip into a slot and a small screw is tightened and hold the wire in place. Here are the instructions that are in PDF format: http://www.dakotadigital.com/pdf/sgi-5b.pdf
Calibration can be done with the key on/engine off, or while the vehicle is running.
In order to calibrate your speedometer, you will need to do it one of two ways that I can think of.
1. Use a scanner such as Auto-X-Ray while you are driving,
2. Or, follow a pace car while going down an open stretch of interstate.
Good luck, Ed
Vintageracer
Jan 10, 2020 05:33 PM
GTAman
Aug 27, 2015 10:29 PM
sailtexas186548
Aug 24, 2015 10:11 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 13, 2015 12:59 PM
