TPS setting for Ford TB with a GM ECM?
Old Oct 8, 2005 | 05:22 PM
LT1guy's Avatar
Car: 1987 Trans Am
Using a GM ECM...what should the TPS (Ford) on an Accufab throttle body be adjusted to? The GM setting or the Ford setting? If its the Ford setting, what are they? I don't have my Ford 5.0 manual available right now. Thanks a lot!
Old Oct 8, 2005 | 06:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would set it to the GM standard of 0.54 volts. Then check WOT which should be no greater then 4.6 volts. Need to watch the high end as some ECM masks will drop out of PE mode if it thinks the TPS voltage is too high. And it doesn't always set a code.
RBob.
Old Oct 8, 2005 | 07:11 PM
LT1guy's Avatar
Car: 1987 Trans Am
Cool, thats what I thought. Thanks a lot!
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
