Which PCM?
Old Nov 19, 2005 | 02:04 PM
ben73's Avatar
Which PCM?
Guys,
Is there a GM PCM that does port injection, SD, and runs a normal dissy (NOT opti) and can control a 4L60e?
TIA,
Ben.
Old Nov 20, 2005 | 02:38 AM
Z69's Avatar
Z69
Have you thought about adding the trans code to an 8D bin?
I think there are enough spare I/O on a 7730 to do it.
Might loose the PWN for the converter clutch but that's not really a loss imop. Just use an older converter.
Might have to get creative to get the inputs in for the gear position but should be doable.
I haven't had time to look into the $OD dis to finish the trans code commenting. Once that's done it might be possible to
do a trans plant.
Old Nov 20, 2005 | 02:40 AM
Z69's Avatar
Z69
Oh yea
Caddy 2240 ecm
Check the DIY board for a discussion on it currently.
grngryoutmyway
Oct 18, 2016 05:48 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
italiano67
Sep 22, 2015 08:42 AM
Roxtar69
Sep 15, 2015 05:24 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
