ecm identification
Old Jun 1, 2006 | 01:20 PM
bizones's Avatar
ecm identification
is there any way to id my ecm if i cant read the stickers?
Old Jun 1, 2006 | 06:32 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
What is the year, make, engine size and type?
Need more input.
Old Jun 1, 2006 | 06:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes. Knowing the model year (MY) and the type of fuel system is the first step. Fuel system can be carb, TPI, TBI, MPFI, etc.
Then knowing the engine can also help: 305, 350, 2.8L, 3.1L, LB9, L98, LHO, LO3, etc.
The final is the BCC code on the PROM/MEMCAL silver sticker. For this drop the ECM down and remove the small cover. On the silver label should be a 3 or 4-letter code (such as CRY, AYJP, etc.).
Let us know and we'll figure it out.
RBob.
{edit: was typing as scuzz was posting, what he said}.
Old Jun 27, 2006 | 10:14 PM
recaroguy's Avatar
Old Jun 28, 2006 | 05:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'm not coming up with anything that makes sense. Using the 'ck' as the BCC shows an '81 2.8L 2bbl engine. Have you checked the service # on the ECM label? If this is for your x-fire I would recommend checking out the crossfire vault.
Here is the URL:
CrossFire Injection Vault
Has a lot of decent tech information.
RBob.
Old Jun 29, 2006 | 10:32 PM
recaroguy's Avatar
Old Jun 30, 2006 | 04:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by recaroguy
RBob-- Yes, this is for my 82 cross-fire, 305. ALSO, there is another number on the prom I just noticed, maybe this will help? 5597 ASY
Thanks again for helping me,....................and what about that last number----5597 ASY.............any good??????????
Yes, that comes up as the LU5 5.0L used in '82 Camaros and Firebirds. Three spd auto and A/C.
ECM # 1225550
RBob.
Old Jun 30, 2006 | 06:33 PM
recaroguy's Avatar
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
