Who is using a scanner that actually works?
Old Jun 28, 2006 | 11:39 PM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Axle/Gears: Dana S60 4:10
I've tried the Actron 9145 with the obd1 cable, no workie. I did see someone on the boards that had the same experience, then switched over the the auto-xray, either the 4000 or the 5000 and had posted that it worked out fine. Any info would be helpful. Gary
Old Jun 29, 2006 | 12:07 AM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
I was wondering if anybody had any luck with that scanner.I was considering buying it, but ended up purchasing a used OTC 2000 which works well.I read some with the Auto Xray had some problems too.
Old Jul 13, 2006 | 11:27 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I've been using the old autoxray scanner since 2000, without a problem, been used on v6's and sd and maf thirdgens and tbi cars, never a problem, except not enough info on the data logger.
Old Jul 18, 2006 | 12:03 AM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
I took the 9145 back to autozone. They said they could order the autoxray 5000, 514.00. I seen it online for about 315.00. Still not sure if it will work.
Not sure what I'm going to do yet. Thanks for the input.
Gary
Old Jul 18, 2006 | 03:14 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I used an Auto Xray on all my cars. 91 Formula 305 TPI, 90 Formula 305 TPI, 87 Firebird 2.8, 86 Grand Prix 305 Carb. I even used it on my current LT1 in my Formula. I bout mine through Summit for $399.95
Old Jul 18, 2006 | 07:53 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
I wouldn't spend $500 on a new scanner, I don't think it's worth it. I got mine on ebay for $75. With that $500, you could get a used laptop and a aldl cable and use a free ware program like winaldl or moates.
Go on ebay and find a used one.
Old Jul 31, 2006 | 10:14 PM
lc tpi's Avatar
the problem you had with the actron is the cp9415 is not for older cars. it is for 96 present. the actron cp9150 is for 95 and earlier and 96 later.i found it for 249 wth all the adapters for basically all domestic cars, on e bay.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
mizz0313
Aug 12, 2015 06:45 AM
