Can the ECM survive under the hood?
Old Aug 30, 2006 | 09:57 PM
DarthD's Avatar
Car: 2001 Trans Am WS6
I have a TPI system from a Corvette. I would like to install it on my 1983 Chevy 3/4 ton pickup. I would prefer not to cut a hole in my firewall because this will be a temporary install. (A few years)
Eventually, I'd like to install an LS1 based engine. Since the computer for the new engine is mounted under the hood, I will be left with a useless hole in the firewall.
Can the TPI ECM survive under the hood?
Old Aug 31, 2006 | 07:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Use a 1227727 ECM. It is a weather resistent underhood ECM. Used in many FWD cars along with the '90 & '91 Corvettes. Can run the $8D TPI speed density code in it.
RBob.
Old Sep 1, 2006 | 01:01 AM
DarthD's Avatar
Thanks for the reply, but the system I have is a MAF system from an '89.
Is water the only issue or is the under hood heat a problem?
Maybe I could seal the housing with some RTV?
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
gta892000
Sep 16, 2015 12:40 AM
64Chief
Sep 12, 2015 08:05 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
