Running a 4L60E
Old Sep 7, 2006 | 12:18 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Running a 4L60E
OK, my 700R is incredibly stupid, and I hate it. I would like to swap in a 4L60E trans so I dont have to deal with trying to get the TV cable right, and I think my 700R is shot anyways.
Is there any ECM that can control a 4L60E and will run my MAF TPI? If not, I am willing to swap to SD if there is a SD / 4L60E ECM that will run a batch injection system (tpi).
Old Sep 7, 2006 | 03:20 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I am running a 305 TPI(1994 305 TBI, LT1 cam, stock O81 heads, SD TPI intake, LT1 TB, 24 lb/hr injectors)/4L60E combo with a 1998 Vortec Van PCM and harness. It adds sequential injection as well.
Old Sep 7, 2006 | 03:27 PM
blander66's Avatar
i belive it can be done with the PCM's from 93-95 trucks so you can keep obd1 and less expensive tuning
Old Sep 7, 2006 | 03:55 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It can be done, look for HaulinA$$.
The MAF Vortec PCM with sequential injection run very well though and gets great gas mileage. I am getting 23 MPG highway in a 4,600 lbs G10 van with 3.73 gears.
https://www.thirdgen.org/forums/tbi/...03-update.html
https://www.thirdgen.org/forums/tpi/...-opinions.html
https://www.thirdgen.org/forums/diy-...ion-gen-i.html
Old Sep 7, 2006 | 04:10 PM
MattODoom's Avatar
Car: '88 G T/A
How does it run sequential? There is no cam sensor on my TPI engine.
Old Sep 7, 2006 | 05:35 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Using the vortec distributor and crank sensor.
Old Sep 7, 2006 | 05:54 PM
MattODoom's Avatar
Car: '88 G T/A
Ahh. From what I've read off those links, the 'black' vortec PCM has a hardwired 5800RPM revlimiter.
Is there an OBD-I style ECM that could run it and still use the chips, software and OBD cable I already have?
Old Sep 7, 2006 | 05:58 PM
blander66's Avatar
the 93-95 truck PCM's can be used, i don't know exactly what needs to be done yet though, im starting to research this for my self also
Old Sep 7, 2006 | 09:27 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
as an alternative, there are many standalone 4L60-E controlers on the market. You could use one of those and run the engine and trans on seperate computers.
Old Sep 7, 2006 | 09:39 PM
MattODoom's Avatar
Car: '88 G T/A
"from what I've heard" these are quite expensive.
Old Sep 16, 2006 | 03:54 PM
MattODoom's Avatar
Car: '88 G T/A
Could I just run a second ECM in my car from a mid ninties truck to control the trans?
Old Sep 18, 2006 | 10:21 PM
Z69's Avatar
Z69
It's been done from what I've read.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
perZ
Aug 21, 2015 05:51 PM
