rapid velocity module
Car: 1982 FIREBIRD-1983 CAMARO
Engine: 305 LG4
Transmission: TH350-TH200
hello guys!well i just bought a 1992 camaro rs 3.1 with a manual tranny!!for greece is quite economical!but i was looking to upgrade it a little so i purchase that rapid velocity module from ebay!the instalation manual says to locate the intake temp. sensor!where is that in that 3.1 engine!please can you post a photo to indicate me!i also notice that the 3.1 engine has no mass flow sensor!
Car: check
Engine: check
Transmission: check
Re: rapid velocity module
The intake air temperature sensor is located in the air cleaner. This is in the right front corner of the car, opposite side of the battery. Has 2 wires going to it.
You may want to re-consider the rapid velocity module. All they are is a resistor to fool the ECM into thinking the intake temperature is lower then it really is.
RBob.
RBob.
Gunner242
Dec 25, 2015 04:49 PM
