No tachometer
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
No tachometer
Hi!
After installing the new msd 6al and a msd coil the tachometer wont work,i have check groundings but cant find anything.
The car runs,i tried to swap back the old stuff but still no tachometer.
Could it be the ecm that been damage or were does the signal to the tachometer comes from.
This is very iritating,it seemes to be a new problem after every mod.
Thanks for any replayes.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: No tachometer
Ok if you ment the coil i have two pink and two white cables,but i dont think you ment those.
Car: check
Engine: check
Transmission: check
Re: No tachometer
Or, try the 'tach out' wire on the MSD unit. I believe that there is an output from the MSD unit that will run the tach. If it doesn't work then the adaptor is required.
RBob.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: No tachometer
Ok thanks!
I tried to reinstall the old coil whithout msd,but still no tach.
Could the tachometer have been damage?Can you messure that the signal is there some how?One of the white cables from the coil are thinner than the other ,is that the tachcable do you think?
Thanks again!
Thanks again!
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: No tachometer
There is some wiringdiagrams at that link: https://www.thirdgen.org/forums/alte...ht=distributor
ambainb
Apr 25, 2016 09:21 PM
