hei into a cam sync
Old May 13, 2007 | 01:11 PM
84camaroturbo's Avatar
Car: 84camaroz28
Engine: 97vortec 350 twin turboed
Transmission: transbraked turbo350
Axle/Gears: 73 chevelle12bolt 366gears
hei into a cam sync
I got the bs3 and i got my crank trigger but every were i look they convert a msd or a ford dizzy to be a cam sync. i need to know how to convert a hei into a cam sync. i dont want to buy a msd just to cut it up and would rather put that money into my injectors. thanks for any help.
Old May 22, 2007 | 10:43 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Re: hei into a cam sync
Um, why not just install another crank sensor on the dizzy base?? I'm assuming your not using the HEI anymore and can gut the dizzy. Seriously, just do the same thing others do to their ford and MSD dizzys.
My bet is you could use the same electronic bits, just assemble them onto the base of the dizzy. If you managed to install the crank sensor, you should be able to do it as well.
If I'm totally off base, maybe you could explain where your getting hung up?
By the way, what the **** is 'bs3'?
Old May 22, 2007 | 12:31 PM
Car: 84camaroz28
bs3 is a engine managment like fast or accell but does alot more for less money. I figured it out called msd if i take the dizzy apart and ground 7teeth off the pickup and 7 teeth off the shaft. then it is a cam sync just dont use the module. then to lock it out i ground the **** were the springs hook drilled and tapped them so i can sync the rtr as well.hear is the link for bs3 if interested http://www.bigstuff3.com/
Old May 22, 2007 | 01:33 PM
pizza_guy's Avatar
Didn't consider that. A lot more work, but no parts to add.
Wow, what did you pay for that?? Along the lines of fast or accell??
Hmmm...I'm happy with my $250 Megasquirt II, but that's for another thread.
Old May 22, 2007 | 02:21 PM
Z69's Avatar
Z69
For those that don't have time or a dist to modify.
http://www.msdignition.com/ignition_..._8506_8521.htm
Old May 23, 2007 | 09:34 AM
Car: 84camaroz28
the bs3 cost me $2200 but it isnt that bad i havent got the motor in yet but it just plugs into gm conectors. the buys who made the accell and fast now make the bs3. my buddy tried to talk me into the megasquirt but i hate to wire and solder. it is supposed to be a kick *** system though.
Old May 25, 2007 | 12:11 PM
pizza_guy's Avatar
Originally Posted by 84camaroturbo
My buddy tried to talk me into the megasquirt but i hate to wire and solder. it is supposed to be a kick *** system though.
The soldering is part of the fun, and wiring is hated by all. Doesn't mean we don't all have to deal with it though.
It is quite flexible for the price, however it can create a lot of headaches if your not good with electronics.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
