Prom Change Question
Old Jul 9, 2007 | 09:51 AM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
Hi ;
I just received my customized prom from tpiparts ;
It has egr,smog,9th injector disabled. I have disabled egr and 9th injector on the engine however I haven't got my smog pump delete pulley yet. Should wait to install my smog pump delete pulley or can I install my new chip with the stock smog pump in place?
Old Jul 9, 2007 | 10:42 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Prom Change Question
Shouldn't hurt anything to put the delete pulley on. Because of NY Inspection laws, I have to have a Smog pump, Cat, PVC on the car. The smog pump shouldn't kick off a check engine light. Only thing that is computer tied in is the air diverter valve. For future reference, You can buy all the equipment from Moates.net to Burn your own chips and give your car a computer tune up. Save your money and don't pay these companies to burn chips which only takes around 3 minutes to configure and 10 sec to burn.
Steven 86IROC-Z
May 24, 2026 04:52 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
