Code 41, any ideas what to look for?
Old Jul 20, 2007 | 09:54 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Hi guys:
I just installed a new 383/vortec into my '88 GTA with a rebuilt (stock) distributor, long tube TPI, stock computer with a custom chip from Hawks 3rd gen, and it's giving me a Code:
41. Fault at cam sensor OR Cylinder select error OR Tach input error
I've checked the wiring to the distributor, but I don't think this car has a cam sensor, and have no idea what a cylinder select error would be. Any ideas what might be the problem or what I should look for?
Thanks in advance
TA
Old Jul 20, 2007 | 11:13 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Code 41, any ideas what to look for?
the trouble tree for that code on your car is,
key off, clear codes, start the motor & run for 1 minute or until code 41 sets.
if it sets code 41, its a bad connection at the MEMCAL or its the wrong MEMCAL.
Old Jul 21, 2007 | 01:39 AM
TA's Avatar
TA
Axle/Gears: 9bolt
Thanks Denn:
I appreciate the help. I'll try all my memcal connections and see what happens after a reset.
TA
1992Vortec
Aug 31, 2015 08:05 PM
mdtoren
Aug 23, 2015 12:52 PM
GouldyGTR
Aug 21, 2015 10:43 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
