Pulled a 32 and 42 : (
Old Aug 17, 2007 | 02:51 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Nothing wrong with the car to my knowledge was driving and the light came on was like hmm prolly needs a new O2 sensor guess not!! I just passed smog, how ever at the 25roll i almost failed NO, could be the egr valve... As for the 42... ?? anyone have these codes pop and fix them? If so plz post what ya did thanks
Rough
Old Aug 17, 2007 | 10:21 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Pulled a 32 and 42 : (
The code 42 will show up after the timing has been checked. My understanding is that in California the smog test has the SA timing checked. Running the engine with the BYPASS connector open will produce a code 42.
Can remove the - battery cable for 10 seconds to clear the codes. Then see if 42 comes back. As you figured code 32 is EGR and it is most likely a mechanical issue.
RBob.
Old Aug 17, 2007 | 11:41 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
yea we had to pull the wire by the blower to check the timing he said it was 4 and should be around 6 but in the limits, as for the egr, just replace it ? and reset ecu?
Old Aug 18, 2007 | 08:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would reset the ECU just to get rid of the codes. That way you know that if any are set that they are new. Otherwise it takes 50 starts w/o an error to clear them.
As for the EGR, it can be any number of items: solenoid, vacuum line, EGR valve, carbon in the head/intake EGR ports.
An interesting item: if the car in question is your '88 TBI, the base timing is 0 deg. Setting it higher to 4 or 6 degrees will increase NOX.
RBob.
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
