ALDL inconsistancy...
Old Mar 5, 2008 | 04:33 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Hey guys... Have an issue that I've been chasing for a while now. It is just coming back to the surface however due to the HSR I just installed and the tuning that I need to do.
I am using Tunerpro RT for chip changes and ALDL datalogging, but there in lies the problem. I am having issues getting the ALDL to give a continuing information stream. It is not all the time, but when it happens it happens over and over.
Basically, I will get the datalogger (have tried more than Tunerpro) hooked up and the ecm connected through the appropriate channels. I will start scanning and viewing the data as it flows, then it will simply stop. It will lock the data in and the connection will be lost. I restart Tunerpro, and try again to connect but most of the time it will not. It gives me an error message that either it failed to initialize the port, or that it could not connect.
Now you can see my issue. Sometimes it takes a while before it will connect again. It does not have this issue all the time, but I'd say at least 50% of the time it will lose the connection.
Any ideas? The ECM is fairly new, but is an Autozone replacement I put in the car a few years back. The car has probably only 3-4k miles on it since then. Maybe a ALDL ground, or ECM ground? The cable hooks up (Moates cable w/ USB converter) so I don't think its the cable. It has the vertical switch and I had to play w/ that at first to connect, but now it is in the correct spot and works sporadically.
Any help is appreciated guys. If you could provide any area's that I need to check that would be great.
Also... this also happened when I was using the Auto-Xray a few years back as well. So this is not a new problem from Tunerpro or the cable...
Old Apr 27, 2012 | 10:22 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
Re: ALDL inconsistancy...
what ended up being the verdict?
xodus2002
Jul 17, 2020 09:08 AM
Veaceonee
Sep 29, 2016 08:15 PM
WejaZ28
Oct 3, 2015 07:38 PM
greenyone
Sep 8, 2015 08:41 PM
Gunsbee
Sep 7, 2015 07:10 PM
