Megasquirt tuning question
Old Apr 5, 2008 | 07:22 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I am at work right now and this is all I can access. I wish I could look at the ms boards, but theyre blocked. ha, anyways, I was wondering in a quick answer how the ms tunes? I know I can use the autotune feature for volumetric efficieny, but I also saw that you can do it for the afr table. Should I leave the Afr table alone for now?
I think, and correct me if I am wrong, that the autotune is best used with autotuning the volumetric efficiency and leaving the afr tables alone right? Like the afr tables are targets that the computer is shooting for, correct?
Old Apr 9, 2008 | 04:29 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Megasquirt tuning question
You are correct sir.
How is it running now? A little better?
Old Apr 10, 2008 | 12:48 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
No. Lol things happened. I gotta get rid of it for now. Im tradin a buddy of mine for his carb setup. Im getting new heads, cam , intake and all. I just have no time for tuning right now. Not until i graduate from college
Old Apr 10, 2008 | 06:48 PM
Toehead's Avatar
Ya, I understand.. Life will do that sometimes.
Hopefully it can get used somewhere
Old Apr 10, 2008 | 07:33 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
If you are still running Megasquirt, I suggest you download the newest version of MegalogViewer. It has a VE table analyzer that is awesome. Check it out, I prefer it to Autotune because you don't have to hold the engine in the cells for a certain time for it to analyze them.
Old Apr 10, 2008 | 09:43 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I already have of it pulled. LOl i got lucky. Fully forged bottom end. dart pro 1 heads nitrous cam and intake with speed demon carb. We shall have updates
Old Apr 21, 2008 | 11:45 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
woot i got the MS and HSR set up lmao.... anyways no job and no fuel pump or gaskets so as soon as i get her running ill give yall updates
Old Apr 22, 2008 | 12:08 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Lmaoo ya well i hope you get it tuned nicely.
Btw I have a extra fuel pumpo fool. I have intake gaskets also. lol. Gimme ur fuel pump. I know you do.
Old Apr 24, 2008 | 01:36 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
thankfully you got it pretty close as long as you werent an asshat and erased the MS lol... i doubt you did but im start fresh anyways.
im pick up that FP im still jobless
MustangBeater20
Oct 29, 2022 09:20 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Thirim
Aug 13, 2015 03:09 PM
