VATS module compatibility
Old Jun 8, 2008 | 03:52 PM
autoxvetteracer's Avatar
Car: 1989 Camaro RS
Engine: mildly built 350 TPI
Transmission: t-56
Axle/Gears: 3.56 lim- slip
I have an 89 RS that i just swapped a 350TPI into. I installed the factory wiring harness for the TPI and i also swapped the ECM too. The motor, the ECM, and the wiring harness are all from a 92 IROC that was totaled and the guy parted it out. Now that i have everything installed, i seem to be getting an intermittent code 46 (pass key failure). Sometimes the car will start just from the key, other times i have to turn the key on and use a remote starter to turn the engine over. i know the VATS module is allowing the fuel pump to engage but for some reason it wont let the starter activate. When i put a tech 1 scanner on it, it says that the pass key is ok. Im wondering if anyone might have any idea what i should start testing/ looking at.
I know that if i go to the dealership and buy a new, unprogrammed VATS module that it will learn the first key that is used to start the vehicle. But i dont want to tear apart my entire dash to get to that module unless i ABSOLUTELY have to. Im wondering if i might just have a faulty wire between the ignition and the starter or if it is just a compatibility problem between the original VATS module and the newer ECM?
Old Jun 14, 2008 | 08:01 AM
MuttlyTheWetDog's Avatar
Car: 87 s10 p/u The Wet Dog
Engine: 86 305 ho soon tbi
Axle/Gears: F8.8 4.56 limited slip
Re: VATS module compatibility
just burn a chip or have a chip burned that vats is disabled no need to worry abought it
that and for how much a new vats modual would cost you could get all the stuff to burn your own chips and get more power and better gas mileage out of that motor
Old Aug 6, 2008 | 05:58 PM
F-Body_Muscle's Avatar
Car: 1989 Trans Am
Axle/Gears: 2.73 posi
Wow. I am having a very similar problem. I replaced the whole ignition cylinder in my car with a brand new one from a dealership. When I turn the key, the fuel pump engages, the dash lights come on, but the car won't turn over. What is this chip that you are talking about and where could I get one? Also, if this disables the vats, can I still use the VATS ignition cylinder or do I have to get one without? Any advice would be great...
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
