Need help with diag
Old Jun 19, 2008 | 11:50 PM
Zenroth's Avatar
Car: 85 Firebird
Engine: 2.8L
Need help with diag
Hello,
Have a 85 firebird 2.8l, multi-port fuel injected, MAF, and having some very strange showings via data logging.
Car seems to run mostly fine it does expereince the odd surging here or there and the mpg has dropped drastically, but outside of these things things are generally smooth and well working.
Everything on this thing has been replaced just about, MAF, MAT, TPS, Coolant Sensor, and O2 sensor within the last year.
My data logging is showing the following:
1. Closed loop is never obtained.
2. BLM seems to be cycling from 20's - high 200's and repeating. (What in the world is going on here)
3. Code 34 is present.
4. Rich flag is set, low battery is set, DRP occured is set, clear flood comes and goes.
5. Error codes 44 and 45 cycle in and out o2 lean/rich
6. O2 levels seem to be too low and too high according to manual they should stay between .35 and .55, I am seeing from 0.049 - 0.9 volts.
I really don't know where to start with this, I've tried to disconnecting the MAF, and clearing codes, and logging data, nothing changes.
Old Jun 20, 2008 | 12:05 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Need help with diag
Which ECM do you have and its BCC?? Post your data log and which pgm did you use to collect this data...
//RF
Old Jun 20, 2008 | 12:20 AM
Zenroth's Avatar
Car: 85 Firebird
Engine: 2.8L
Its the stock 85 ecm, at 160 baud not sure what the number is on it. I used winALDL.
Attached is the file.
File Type: txt
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
Dirty Dave
Aug 13, 2004 12:25 PM
