NEW adapter board for megasquirtII to 86-88 tpi cars
#203
#205
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: NEW adapter board for megasquirtII to 86-88 tpi cars
Someone should tell them that there are a lot more vehicles than the 90-92 F-bodies running around with the 1227730. Namely just about every FWD V6 produced between 86/7 (88+ I'm sure of) and 94 (except W-bodies). And vehicles that have been adapted to use the 730. Oh, well.
A question about these adapters and installation into the 165/302 case...
Just how do these things mount? I can see it's obvious how the adapter mounts, but the MS? Am I supposed to get some sort of standoffs or something?
#206
Engine: 2.7L V6
Axle/Gears: 4.41
Adding some info here...
Went and did a Google search last night for "GM ECM connectors" and came up with the following part for the 56-pin connector as is used on the 165 and similar ECM modules. I ended up doing a search because the junk ECM board I was going to scavenge the connector out of has gone AWOL on me .
Mouser carries the Delphi 12110209 56-pin ECU connector. It's light blue, however, not black, for the purists out there, and it's the only color it comes in, apparently. It's $13. If you'd rather not hack up an ECM, this is a good option.
#207
1 Post
Car: 88 Trans am
Axle/Gears: C4 IRS 3.42
Zombie !
Are these still available ? The one linked to in post 200 does not seem to be the same unit discussed earlier. I guess there was not any further development for the 3-connector style ECM's ?
#208
I've ran MegaSquirt I, II, and now III and always found these threads to be ridiculous. Just cut the vehicle's harness 6" before the stock ecm connector and solder in the new MegaSquirt harness. Save the old harness and if you want to go back just cut again and resolder. If you really have to use a stock connector than buy a junk ecm and desolder the connectors from the PCB and reuse that connector. One of the main MegaSquirt suppliers made and sold these conversion boards and after a year had them all on clearance because the overwhelming majority of MS users have no problem with rewiring, soldering or making their own harness. They were even on clearance for a looong time because again, MegaSquirt users didn't need them. Not trying to be rude but if someone is trying to find a conversion box to avoid work then the world of MegaSquirt is not for them.
#209
1 Post
Car: 88 Trans am
I hear ya !. But not everyone wants to hack the harness. Being able to go back to stock easily is a definite advantage. It seems the lack of a 3 connector version for 90-92 cars probably killed the appeal too.
The main black connector can be found new, But cannot find that yellow 3rd connector from any supplier, Could hack a junkyard ecu to get the connectors, true, but the '730 ECUs that used the 3rd connector seem to be getting more rare and expensive. Every car at the junkyard locally that had one has been plucked. Ebay units are over $100.
The adapter board could also have some electronics on it to handle the stock vehicle systems. Stuff the Msquirt does not do.
#210
There is much that MegaSquirt I can't do. MegaSquirt II can do everything the stock ecm can do but will need an add on controller. MegaSquirt III can do everything a '730 does and more. Then there is MS Pro that is possibly the best fuel injection controller available.
#211
Car: check
Engine: check
Transmission: check
Diagnostics of sensors? Proper closed loop fueling to keep a cat-con active?
RBob.
#212
After writing all of that you've proved that I need to clarify my prior comment. As I have said in the past the MegaSquirt world is not for someone who wants a diagnostic port to flash trouble codes, it's not for someone who needs to control emissions equipment and it's not for the set-it-and-forget-it crowd.
#213
1 Post
Car: 88 Trans am
If I am not mistaken, The 7730 ECU handles the raw VR signal from the trans sensor and provides the signal to run the speedometer, eliminating the "yellow box" on earlier cars. ?
As said, TCC control is quite refined in the stock ECU based on various data, or can be crude with aftermarket solutions.
Even the $$ MS3 cannot handle the raw VR signal from the speed sensor on the trans. It needs an adapter board. Thus my suggestion that the plug in adapter subject of this thread could incorporate those electronics. Looking through the posts, many just wanted a "plug and play" option for the 90-92 cars.
#214
Car: check
Engine: check
Transmission: check
RBob.
#215
They didn't disappear because they weren't popular, they disappeared because they had a design flaw that made them a headache to build.
#218
colton_carlson
03-08-2019 12:21 PM
NBrehm
08-25-2015 11:49 PM
