91 Z28. codes? 33, 44,45, and 46?? TPI
Old Jul 1, 2009 | 06:10 PM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
Im still trying to find a good book or thread for chevy codes. I could use some help on these 4 codes. Thanks gentlemen
Old Jul 1, 2009 | 06:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 91 Z28. codes? 33, 44,45, and 46?? TPI
https://www.thirdgen.org/service-eng...ht-error-codes
The best book for troubleshooting is the Helm FSM.
RBob.
Old Jul 1, 2009 | 07:58 PM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
thank you sir
Old Jul 2, 2009 | 01:59 AM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
I reset the codes by unhooking the battery. Now im getting a code 44 constantly. That means Oxygen sensor is lean. I understand what lean means, but does that mean the Oxygen sensor is bad? I went ahead and pulled it out. Its burnt to heck. The car stalls out all the time when I brake after it gets good and warmed up. Im tired of having to start my car in middle of a stop sign or traffic light. Any insight???
Old Jul 2, 2009 | 08:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It may be that the O2 sensor is bad. I would check the fuel pressure first. That is certain to cause the issues you are seeing (including the code 44).
RBob.
Old Jul 2, 2009 | 11:48 AM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
Ill see if I have a way of checking the fuel pressure. If fuel pressure is the case, how do I get more fuel pressure? Fuel pressure regulator?
Old Jul 2, 2009 | 02:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is a fitting on the fuel rail to connect a gauge. If the pressure is dropping off common causes are: filter is clogged, fuel pump is dying, turtle is leaking, inadequate voltage to fuel pump.
RBob.
Old Jul 2, 2009 | 04:41 PM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
I put the new o2 sensor in. It seems to be running alittle better. i need to drive it around some more to really tell. Ill check all the fuel sources and go from there. Thanks for your help.
Old Jul 3, 2009 | 01:07 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Most common source of a lean code is a vac leak... Have you read your plugs? That would indicate if its actually a lean condition or a sensor failure.
GouldyGTR
Aug 21, 2015 10:43 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
