fried chicken ?
Old Aug 22, 2009 | 03:58 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
fried chicken ?
ok so i have been having problems with my 88 tbi bird , to start off it runs super rich . , i bypassed my coolant fan switch , so it would stay on all the time , little did i know this would affect my car greatly . it set off a coolant tempature code , now i didnt know that by keeping my engine cool it would make my ecm think that my engine is cold and have it always in enrichment mode " i think thats why im running rich eventhough my spark timing is right " now heres my question DID I FRY MY ECM ? i was checking codes and had the jumper wire that goes into the diagnostic terminals and i cranked my car over and it ran then i shut it off and ever since then it wont start , any ideas what it might be ?
Old Aug 26, 2009 | 04:39 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: fried chicken ?
Cranking with the A+B jumpered will not do anything to the ECM. This just places it in field test mode. It does close the IAC, however. You might try starting it with the throttle cracked open.
You should run a stock 195 t-stat with stock fan switch. Right now, teh engine is constantly running rich in open loop (and the TBI cals are set to run RICH). You could have possibly fouled out the spark plugs, causing a flood and no-start. Check the plugs to see what they look like. If theyre real wet, you will need to disconnect the injectors and crank the engine over to clear out the fuel and put in new plugs.
Old Aug 26, 2009 | 08:55 PM
Re: fried chicken ?
i figured out my problem , i used to have the ac delco's in there before the rebuild but i broke a couple and decided to try the e3's , turns out my coil went out and the e3's need a little more juice to run em ' so i bought an msd blaster coil , hopefully that fixes the problem , now all i have to do is get bird running , another prob though since i was trying to set the timing previous to the stock coil going out i have my distributor loose now i twist it a little bit and have someone crank it and it wants to start but as soon as they crank it it floods so i have to disconnect the injectors and crank it then i can get a really rough idle for a while " at least until the fuel in the piston runs out , so during the idle i plugg the connectors back in and it pops like it wants to back fire
Old Aug 26, 2009 | 10:11 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: fried chicken ?
cranking it at WOT should put it in flood clearing mode, and turn off the injectors
Old Aug 26, 2009 | 10:19 PM
Re: fried chicken ?
yeah thats what i do , with the injectors connected i prime the pump then crank but as soon as i do that it floods , and then i have to do it all over again but with the injectors disconnected , crank it then let it run until it dies oot .
Old Aug 27, 2009 | 03:11 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: fried chicken ?
In the TBI ECMs, it sets the AFR to 20:1 to clear the flood. They still deliver fuel, but not as much.
Old Aug 27, 2009 | 03:19 AM
Chevy8588's Avatar
Re: fried chicken ?
i miss read, thought it said TPI >.>
Old Aug 27, 2009 | 05:05 PM
Re: fried chicken ?
cool , i got my coil bracket put together today , lets see what happens ...
Old Aug 28, 2009 | 12:39 AM
Re: fried chicken ?
well , not so good news , first off msd blaster coils aren't direct fit " one of the manifold runners is in the way of the new , bigger msd coil , so i only bolted one hole ." two my darn bird still floods , first off i tried cranking it without the injectors disconnected and it ran for a while the died " i had to hold down the distributor and twist it to find the sweet spot ." so the i tightened the distributor a little bit more and got it to stay put . plugged the fuel injectors back and cranked but nothing " it sounds like it wants to start but nothing , so then i spray starting fluid in tb and its starts then dies when all starter fluid is used up . so i dont know what else could be my problem , my fuel pump relay is brand new and i even rebuilt my tbi unit so no cloggs in filters , what else could it be ?
Old Aug 28, 2009 | 01:28 AM
Chevy8588's Avatar
Re: fried chicken ?
if its flooding, there's too much fuel dumping and not enough burning. your injector pods stock?
Old Aug 28, 2009 | 06:50 PM
Re: fried chicken ?
yes , tehy are and i just rebuilt my tb unit , it cost me 40 $ not bad , but yeah oh uh also could it be my pluggs ? because i am using the e3's and i broke one and bought a new new one and after only 10 minutes of running it " back when it was running and it ran super rich " the electrode was black , could that be it ?
Old Aug 28, 2009 | 07:32 PM
Chevy8588's Avatar
Re: fried chicken ?
get those E3 plugs out and use autolite plugs for it, they stop internal arcing for a better burn on these motors, and anyone who doesnt believe me, try them and feel the diference
Old Aug 28, 2009 | 08:24 PM
Re: fried chicken ?
really . are e3's that bad?
Old Aug 28, 2009 | 09:10 PM
Chevy8588's Avatar
Re: fried chicken ?
any multi electrode plug is nothing more than snake oil, and every multi electrode plug ive ever used has givven me a rocky idle, if your flooding, you either have weak spark, fouled plugs, too much fuel, or not enough air.
Old Aug 28, 2009 | 09:15 PM
Re: fried chicken ?
ok , you now how there is a star bolt on the right side of the tb unit , that controls air flow right ?
Old Aug 28, 2009 | 09:19 PM
Chevy8588's Avatar
Re: fried chicken ?
yea, you think you are haveing an issue with minimum air??
Old Aug 28, 2009 | 09:21 PM
Re: fried chicken ?
could that be the cause of my problem ? it has been messed with " not by me "
Old Aug 28, 2009 | 09:25 PM
Chevy8588's Avatar
Re: fried chicken ?
what was done JUST before this issue, do you have a coolant temp sensor in there now?
Old Aug 28, 2009 | 09:27 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: fried chicken ?
Might have missed it runnin thru past post.... Did u test your ECM? Done for free at autozone....
Old Aug 28, 2009 | 09:32 PM
Re: fried chicken ?
yeah its always been there all my supervisor did to bypass the sensor is he spliced a wire in the harness that goes to the relay and then he grounded that wire so whenever the ignition was on the fan would also come on , then i drove it home thinking the white smoke was oil from me touching all those internal parts with my greasy hands , then i realized it was raw gas not oil so we thought the timing was off , so we messed with that with the est unplugged then we shut off the car plugged the est back in and the timing wouldnt stay set so i re did my timing and still no chang but my supervisor forgot to unplugg the est when messing with the timing , then he shut it off and ever since then its been hard to start
Re: fried chicken ?
no i havent i didnt know they did that , btw those things arent cheap $77.00
Old Aug 28, 2009 | 10:08 PM
Chevy8588's Avatar
Re: fried chicken ?
get that coolant temp sensor plugged back in and hooked back up right, then set your base timing to 6* BTDC
Old Aug 28, 2009 | 10:11 PM
Re: fried chicken ?
yeah , i'll do that and mess with that star screw and see what results i get
Old Sep 1, 2009 | 10:42 PM
Re: fried chicken ?
okay , new ac delco's are in and e3's are out , messed with the star bolt and nothing , now i have a dead battery
RedLeader289
May 28, 2019 01:47 PM
chazman
Aug 28, 2018 03:25 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
chazman
Aug 22, 2015 02:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
