No ALDL feed on AUTOPROM
Old Sep 13, 2009 | 07:03 PM
rvgriff's Avatar
All,
I just recently purchased an APU1 USB version from Moates.net. I am using a 1227727 ECU with TunerPro RT. The emulation part seems to be working fine but when I go to use ALDL to see what everythign is doing I am getting no data feed. The APU1 shows connected but no feedback. I am using the same ALDL definition as I am using for the emulation. By that I mean the same as the 1227730 ECU bin and ALDL code from TunerPro.net. I do have the dip switch on the APU1 set to log ALDL data but not getting data. I tried a few different ALDL definitions with no success as well. Looking for a little direction here....
Thanks in advance.
RVGRIFF
Old Sep 18, 2009 | 10:59 AM
rvgriff's Avatar
Re: No ALDL feed on AUTOPROM
Figured it out so for anyone else that has this issue do the following:
In TunerPro RT go to Tools > Preferences
Under the ALDL tab select AutoProm for Interface type and leave all other defaults.
The AutoProm will detect the correct port and send the signal data to TunerPro RT. Hope this helps someone else down the line.
tmellott89
Oct 14, 2015 02:06 PM
FormulasOnly
Oct 2, 2015 05:52 PM
dusterbd
Sep 29, 2015 08:40 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
gta892000
Sep 16, 2015 12:37 AM
