VSS input for 7730 ECM
Old Feb 9, 2010 | 09:47 AM
LittleNo's Avatar
Car: 91 TPI Caprice
Transmission: TH700R4
a short question: at the 1227730 ECM with 8D (running a TPI) I usually have the VSS directly connected to the ECM, and the ECM supplies the output signal for the speedo (basically the ECM has the function of former VSS Buffers)
Now i have a 89 Van with mechanical speedo and a speed-sensor attached to the speedo, which supplies a brown speed output wire to this Van's factory TBI-ECM.
Is there a way to use this signal at the TPI-ECM? it would safe me a lot of time because otherwise I would have to get a new VSS.
Old Feb 9, 2010 | 10:57 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: VSS input for 7730 ECM
They used that computer in different applications with an optical sensor.
Connect that brown wire to C6 on the computer. and disregard the B9&B10
Old Feb 9, 2010 | 08:52 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
That will work but you must be able to reprogram the chip.
Option word 3 at $8018, bit 6 must be cleared to enable to optical input.
Old Feb 10, 2010 | 01:33 AM
LittleNo's Avatar
Car: 91 TPI Caprice
thank you guys, that's great
I'm using Tunercat for programming, can this option be set there too?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
cheesehomer
Dec 31, 2015 08:48 AM
Jlanz55
Sep 29, 2015 08:55 AM
