timing
Old Mar 10, 2010 | 04:07 AM
dave85's Avatar
timing
how do i set the timing on a car w/cab i read that there is a brown/black wire to disconnet i dont see a brown/black wire
Old Mar 10, 2010 | 04:13 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: timing
Is your distributor cap separate from your coil? if it is then the ignition module underneath the distributor cap has two plugs, I believe you unplug the first one to the left... you will notice a decrease in rpm and your idle will be noticeably different...
Old Mar 10, 2010 | 12:12 PM
Ronny's Avatar
Re: timing
what does w/cab mean?
I thought there was a yellow/brown wire on firewall near brake booster. It protrudes out of wire harness with a male/female. Disconneting removes control from ECU. Initial spark timing I recall is somewhere on a label under hood for you car/motor. Mine I recall was 6 dSA.
Old Mar 10, 2010 | 12:33 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: timing
I believe he meant Carb...
you know on the actual prep work, on mine I have to either ground the ECM at the diagnostic port, or pull the connector from the ignition module...
Old Mar 10, 2010 | 05:44 PM
dave85's Avatar
Re: timing
yes carb, point me in the right direction of ecu. and the coil is built in the cap.
Old Mar 10, 2010 | 10:31 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: timing
the 4 wire connector to the dizzy
Old Mar 11, 2010 | 10:15 AM
Ronny's Avatar
Re: timing
cant find yellow/brown as I stated? Is your dist stock controlled by ECU(rpm/map referenced)? Or is it traditional mechanical centifugal/vac?
Old Mar 11, 2010 | 11:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: timing
For a CCC large cap distributor it is what chads89ta posted. There should be a 4-wire connector near the base of the distributor. The wires exit from the distributor at the base of the cap. Disconnect the 4-wire connector to put the distributor into bypass mode.
RBob.
Old Mar 11, 2010 | 05:35 PM
dave85's Avatar
Re: timing
i found it thanks.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
