EBL and EZ-EFI throttle body
Car: check
Engine: check
Transmission: check
Re: EBL and EZ-EFI throttle body
So at this point what would be the best solution? Voltage boost, ditch the ez-efi, or run them as separate injectors (each with their own wires) or....?
How much compensation is done from the MAP vs the AFPR tables? I looked at the instructions to the EZ-EFI kit and found that it says to use an AFPR with the kit which leads me to believe that it has AFPR tables built into the kit. Reason I'm asking is that it would be a whole lot easier to run the complete EZ-EFI kit out of the box rather than hooking up the TB to an EBL. If drive-ability and power are highly dependent on using the MAP to compensate for boost only then would it make sense to go through the extra effort to use the EBL (then of course there is the spark control too). I could just be getting burnt out at this point and just wanting to quit but I might accidentally be on to something too.
With using the EBL will I need a knock sensor? If so, where would it go since I don't have a modern block? And which knock sensor would I use?
You don't have to run a knock system (ESC) with the EBL. But on a boosted engine it is recommended. I placed it in the drain hole of a '68 SBC block. Which is where GM places it in the GEN SBC's that come with an ESC system.
RBob.
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
"Q3) Where do I put the knock sensor?
A3) Passenger side water jacket drain plug - just above oil pan rail. Be forewarned that it is best to remove this plug while engine is out of the engine bay. These plugs are known to rust-in and break while removing. Drilling a pilot hole and right size easy-out is only way I know to get them out! It is PITA."
Found this on another forum, is that accurate and do you have another (hopefully easier) way to remove the drain plug? Am I going to be dumping lots of fluid when removing this?
Is this the right PN: 350 knock sensor - GM 10456288?
Thanks for all the help so far Bob and sorry for the stream of questions.
Engine: 355
Transmission: 4L60
Just got off the phone with motorvation and he said their 1150cfm TB runs the long style TPI/LT1/etc. injectors either high or low impedance (said $324 for (4) 83# low saturated), this is more of what you're wanting to run, correct?
Also found for a bit cheaper: 83# FAST Injectors on Ebay would those work?
Also heard back on the powerjection setup...no go, they don't use a narrowband and don't have spark control yet.
Car: check
Engine: check
Transmission: check
Is that drain hole properly tapped already or is it a push in style thing?
The correct knock sensor would be for a GM TBI system. Say a '90 full size van (K van) with a 350.
RBob.
Car: check
Engine: check
Transmission: check
• 1150 cfm Injector Throttle Body has provisions for 6 injectors, supports power levels up to 1000 HP
• Ideal for turbo / blown applications where additional injectors are needed for extreme power levels
So, I don't know how they are set up.
The FAST injectors are OK. Here is a set of Deka I 83 #/hr low imp injectors that are good:
http://www.bmotorsports.com/shop/pro...roducts_id/621
And the Accel TBI unit that takes 4 standard port injectors:
http://www.accel-dfi.com/ProductDeta...tSearch=74135B
To be honest I don't like the idea of a TB requiring a modified injector that is only available from one source. And then only offering high impedance injectors at that.
RBob.
Engine: 355
Transmission: 4L60
No rails, 1000cfm, all electronics:
http://www.amazon.com/gp/offer-listi...&condition=new
I could get the rails from here:
http://www.auto-nomics.com/cgi-bin/s...part=10910-005
Or try getting a set from motorvation since they use the same setup on their Accel replicas.
OR:
750cfm - All electronics and rails included:
http://www.summitracing.com/parts/MVC-950750/
What do you think?
OR:
What do you think?
Engine: 355
Transmission: 4L60
Sprung for the 1k CFM unit since it's cheaper ($310). Working on getting some rails ordered for it now, we'll see how that goes.
Ordered the 83# Deka's and pigtails for $262 and knock sensor, knock module, and map for $158.
Just need to dig out my ECM to get it sent in now, it's a pain finding everything after having it in storage for a year.
Engine: 355
Transmission: 4L60
Looking over the wiring diagrams on the dynamicefi.com I came up with a few questions...
Does the VSS box need to be in place between the sensor and ECM or can I run it direct?
Is the wiring diagram for the injectors only for the 4-injector upgrade or is this the same way I need to hook them up?
I'm guessing no for all of these but do I need to hook up: VATS (B6), High Idle (B9), anything for the trans/TCC/Park/neutral (my 700R4 is setup for standalone operation), the oil pressure switch, and the ALDL stuff (A8, A9)?
Can I tie in all (or some of) the 10 amp fused 12 volt ignition switched leads or does each one need to be on its own fuse?
Engine: 355
Transmission: 4L60
Been super busy and totally forgot to ship out my ECM! It's going in the mail today and will be getting the TT-1 to use with the EBL and putting my LC-1 in my LQ9 Jeep.
Will the TT-1 work by itself since it has a narrowband sim or will I still need to use both it and a narrow band separately?
Sorry for the constant barrage of questions, just don't want any surprises since this is my only vehicle til I move back to NY where my Jeep is waiting.
Car: check
Engine: check
Transmission: check
VATs and high idle are optional, the TCC is optional. A park/neutral switch is nice to have but not mandatory. It helps prevent stalling when shifting into gear. Can crutch it by having the engine idle in park/neutral a little high on the throttle stop screw. And with some IAC counts when in gear.
ALDL is optional, but is available for use with a standard scan tool (diagnostics), flashing codes, and running the IAC.
The oil pressure switch is optional. It is a bypass for the fuel pump relay in case it or the ECM FP relay driver fails. Note however, that the fuel pump input to the ECM (B2) should be connected. It is used for injector compensation vs. system voltage.
The ignition switched power can be grouped together more on a lower number of fuses. IIRC, the diagrams show more along the lines of how it is OEM. Having the injectors separate is a good idea.
Injector wiring: it will be the same as shown for the 4-injector upgrade.
RBob.
Car: check
Engine: check
Transmission: check
Since this usually leaves the NB O2 sensor in place, it is easier to just use it. The 2nd output on the TT-1 can then be used for a gauge, or even to a DVM for a quick reading without a laptop.
RBob.
Engine: 355
Transmission: 4L60
The magnetic and optical type sensors needs a buffer box. There are some 2-pole digital sensors that do not need a buffer. The ECM VSS input is 2K PPM, digital (square wave) input.
RBob.
RBob.
My B&M shifter has a neutral safety switch...can I wire it up to the ecm?
The rest of the stuff will likely be wired up eventually
The TT-1 has a simulated NB output that can be used in place of a NB sensor. The catch is the location. The WB sensor needs to be in a cooler area then a NB sensor. So down under the vehicle prior to the cat is the best location.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
The speed sensor is from my 92 olds wagon, it's the digital 2-wire.
The LC-1 is still running like a champ after 3k miles installed in my long tubes, guess I got lucky... is there a recommended distance on how far back (I don't have cats) and is there a wiring diagram for hooking it up for auto tune with the EBL software or is that included in the WB software to use separately?
The P/N input to the ECM is as follows: open in drive, grounded when in park or neutral. Using a plain 12V relay, one end of the relay coil goes to IGN +12 volts. The other end of the relay coil goes to the P/N safety switch. The end that goes to the +12 cranking voltage from the ignition switch.
This has the relay being activated whenever the ignition is on and the shifter in the P/N position. It finds ground through the safety switch and then through the solenoid coil. The current isn't high enough to activate the solenoid. But the relay does close.
Shift into a drive position and the ground goes away. And the relay opens.
The relay contacts: common (C) it tied to ground, normally open (NO) goes to the ECM.
During cranking the relay will open showing 'in drive.' But that doesn't matter as the ECM doesn't care about it during cranking.
You can find the TT-1 WB manual online at:
www.dynamicefi.com/TT-1_UsersManual.html
RBob.
Engine: 355
Transmission: 4L60
And here I was thinking I went through all the pages on your site. Apparently missed that one!
Thanks for clarifying the P/N switch. I really need to pull that harness out and start modifying it while waiting for the rest of the parts to arrive.
Car: check
Engine: check
Transmission: check
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
