Constant knock sensor reading…
Old May 30, 2010 | 07:50 AM
Jerry D's Avatar
My problem is that I show 25.8 degs retard value from the knock sensor through the GMC 16168625, using TunerPro RT. This is a TBI install on a six cylinder 4.2 L Toyota engine with manual transmission. I’m using components from a ’93 GMC Safari Van that had the V6 with auto transmission. I have swapped ECMs with another 16168625 but had to use the same MEMCAL. I am using TurnerPro RT to trouble shoot and hopefully fine tune. I have a store bought ALDL cable with USB connector. I have checked continuity from the center of the wire that connects to the knock sensor to the plug at the ECM, and it’s at 0 ohms, so the wire into the ECM is good.
With either ECM I get the following:
With the knock sensor wire connected or unconnected at the knock sensor (and yes, I do have a bad knock sensor that has to be replaced) TunerPro RT shows 25.8 degs retard.
When I put a 3.9K ohm resistor from center of the knock sensor wire to ground, I still show 25.8 degs retard.
As for voltage, with using a 3.9 K ohm resistor from center of wire to ground, I get 2.4 Volts at the ECM plug, and still show 25.8 degs retard.
Could I have two bad ECM’s, or can the MEMCAL be the problem??? Is there any other way to test the ECM before I try to find another??? Is there a way to test the MEMCAL, I read about a knock sensor filter (?) but truly don’t understand what it is or where. Perhaps I don’t know how to set up TurnerPro correctly.
Any input, I can take criticism well, would be appreciated.
Thanks,
Jerry D.
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
