wire harness for 730 ECM??
Old Sep 27, 2010 | 02:14 PM
Shane87irocz's Avatar
Car: 1987 IROC-Z
Engine: L-98 350 TPI
I am upgrading my 165 ecm to the 730 ecm but cant find any wire harness. Does any one have one or know where i can pick one up.. Call junk yards and call Hawks. Hawks will only sell the hole harness for $200
Also Looking for the pin adapter and a stock prom for the 730. Thanks!!!
Old Sep 27, 2010 | 03:10 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: wire harness for 730 ECM??
Dont be too quick to disregard the Hawks $200 deal if they have what you need. Custom harnesses can easily exceed that figure.
Good luck
Old Sep 27, 2010 | 08:29 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Can I assume you still have the 165 harness? If so, just re-pin it. That will be easier than swapping out the whole harness. There is a sticky that has a link to the site that will explain how to do it.
Old Sep 27, 2010 | 11:23 PM
Car: 1987 IROC-Z
Is this what you are talking about www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Don't i need to get the harness from the 730 Ecm with the 3 snap in connectors??
I have the 165 in the car and just got the 730.
Old Sep 27, 2010 | 11:54 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
You can do in 2 ways.
1. make a adapter harness like in the link above
2. you can rewire your existig harness
in both cases you'll need connectors that fit the -730 ecm.......shouldnt be to hard to find.........
Old Sep 28, 2010 | 10:33 AM
Car: 1987 IROC-Z
So if i rewire my harness all i need is.. 730 Ecm, prom, pin connectors, map sensor W/harness and knock sensor for a 90-92 camaro/firebird. Thanks!!!
Old Nov 28, 2010 | 01:12 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
If you get an aftermarket harness, make sure it has provisions for a VSS. Some resellers omit it saying it is not needed. Wrong in most instances as it controls many things in the ECM.
Old Dec 25, 2010 | 07:45 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
you could do what i did, i went about 4" from the firewall plug and cut my existing harness, then spliced the 92 harness into the 89 bulkhead plug. alot of it is or was an easy match, starter wires, etc. i also had a wire harness and c100 diagram from both years, maf and sd. the sd harness was complete, so the only wires i had to splice was the ones near the power brake booster, i will have to swap some pins on the computer to underdash harness when it's time. either way, good luck man.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
355tpipickup
Aug 19, 2015 10:02 PM
