Electronic Spark control code
Old Jan 20, 2011 | 12:45 PM
camaroman9191's Avatar
Hi all, I have a 1991 Camaro Z28 with a 305 TPI. It's an "F" code car. It has set an Electronic Spark Control module SES code a few times and I want to know where the ESC module is.. A location would be great if you know.. Thanks
Old Jan 20, 2011 | 12:50 PM
Re: Electronic Spark control code
And does the ESC module have anything to do with the knock sensor and is that the only sensor it uses?
Old Jan 20, 2011 | 03:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ESC module is inside of the ECM on the MEMCAL. See sticky up top for picture.
The ESC sensor is on the engine block, right side, in front of the starter right above the pan rail. Most likely the connector is going bad. Second likely issue is the sensor is going bad.
RBob.
Old Jan 20, 2011 | 04:06 PM
So the likely hood of the actual module in the ESC is very slim correct? and thank you for your help!
Old Jan 20, 2011 | 04:21 PM
EagleMark's Avatar
The ESC "KNOCK" sensor is on the engine block, right side, in front of the starter right above the pan rail. Most likely the connector is going bad. Second likely issue is the sensor is going bad.
RBob.
Pretty sure he meant knock sensor, above, in his quote, in red.
and yes more likely the knock sensor then ESC...
Old Jan 20, 2011 | 05:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, the knock module (filter) rarely goes bad.
RBob.
Old Jan 20, 2011 | 05:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The Electronic Spark Control (ESC) system is the knock detection and reporting system. It consists of the sensor and the filter (module).
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
mddaniel
Sep 8, 2015 05:16 PM
db057
Sep 4, 2015 07:57 AM
