prom change from auto to manual trans?
Old Apr 29, 2011 | 08:04 PM
combatdoc's Avatar
Car: 91 z28, 92 ZR1
Engine: LS1, LT5
Transmission: T56, ZF
Axle/Gears: 3.73/ 4.10
i have a 92' rs that i put a 87 l98 tpi motor in and used a SD tpi off 92 z28, my car is a 5 speed but the ecm is out of an auto car, what prom should i be using? and where is the best and cheapest place to get one, any help will be welcome.
Old Apr 30, 2011 | 07:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: prom change from auto to manual trans?
There are no stock 5-speed (or any stick) calibrations for L98 engined f-body's. And a y-body calibration for an l98 is for use with the '113 aluminum heads.
RBob.
Old May 2, 2011 | 12:18 AM
complete loser's Avatar
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
I have a similar question. I have an 89 auto prom. I will be running a manual. What is the best course of action? If no factory bin files exist for such a setup, is there some proven manual trans files available?
Old May 2, 2011 | 11:04 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
just run the 350tpi stock prom, you just won't have a shift light on your dash. And make sure you have the VSS plugged in or the car will stall at stops.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
Leggman1
Aug 6, 2015 04:15 AM
