Issue with 165 ARAP car stalls when put in gear
Old Nov 29, 2011 | 10:34 AM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Hey fellas, a friend of mine is having some issues after swapping a complete 89 TPI 350 w/trans into a 78 T/A all stock motor nothing fancy. The car starts just fine, but when you put it in gear it stalls. The timing is mechanically set to 10* initial and also in the chip. I have tons of experience with 730, but very little with MAF tuning. He had a chip burned from Arizona Speed to remove VATS and added some timing. My question is; Does the 165 ecm automatically add the initial to the spark table or do you have compensate when doing that table? I say that because I know 730 does. Thanks for your help. I really think this guy has other issues.
Old Nov 29, 2011 | 10:42 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Issue with 165 ARAP car stalls when put in gear
how did you guys hook up b10?
Old Nov 29, 2011 | 03:16 PM
zz17iroc's Avatar
You are referring to pin B10 Park/neutral SW right? He ordered a painless harness and I did not have anything to do with install. Another buddy of mine is trouble shooting his install because he is local.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
killer777
Aug 8, 2015 02:47 PM
