need help with splicing ignition switch for FAST harness
Old Nov 30, 2011 | 07:58 PM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
Hey I diid a search and didn't find what I was looking for, I have a FAST dfi and I was wondering what the best place to splice into for the 12 volt ignition switch...says should be spliced in where power is given during starting and running postion??? Also can I splice my msd box (7AL-2) ign. Switch port to this same splice as the dfi?
Thanks for any and all help
Dave
Old Dec 1, 2011 | 10:46 AM
Re: need help with splicing ignition switch for FAST harness
Bump
Old Dec 1, 2011 | 01:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Should be some IGN openings in the fuse block (to left of drivers foot). I can't recall exactly what I used to tap in, but a male fast-on tab comes to mind. Note that some are BAT, which is battery power (on all of the time).
It is best to test the tap by putting the ignition key into the ACC position. If there is power on that tap then do not used it. It will be cold during cranking.
A quick summary, there are three types of power feeds:
BAT, battery power, hot all of the time.
IGN, ignition switched, hot during key-on and cranking.
ACC, accessory switched, hot during accessory-on and key-on, cold during cranking.
RBob.
Old Dec 1, 2011 | 01:35 PM
Ill check the fuse block, now battery in car yet, still finalizing all the wiring....thanks for the help!
Old Dec 3, 2011 | 07:23 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
what FAST system do you have, XFI or the EZ?
Old Dec 3, 2011 | 07:30 PM
Niether, its model # 30-213311....sequential fuel injection...pretty much same as big stuff 3 just nitrous friendly over boost friendly....I had BS3 but traded for this ecm,600 bux and a msd 7al-2 box..from a buddy that was boosting his car
Old Dec 3, 2011 | 07:54 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
is the ECM silver? sounds like a FAST classic system.
Old Dec 3, 2011 | 08:02 PM
Yup its silver, SEFI born year of 2004
Old Dec 3, 2011 | 09:14 PM
Yup? Its silver SEFI born year of 2004
BRoss99
Aug 10, 2025 05:08 PM
Fast355
Dec 2, 2016 06:33 PM
stalkier
Dec 6, 2015 11:25 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
