Problem understanding the vacuum diagram?
Old Jun 8, 2012 | 11:07 AM
Mad_Max_63's Avatar
Car: 1984 Camaro
I hope I have posted in right sec. Anyway I have a pin of my vacuum diagram and was wondering if someone can help me figure out the route these hoses go? I also cant understand the thermostatic vacuum switch connection? as you can see the tva diagram seems different from the carb diagram. Anyway can someone please help me, thank you!
Attached Thumbnails Problem understanding the vacuum diagram?-0996b43f8020e107.gif   Problem understanding the vacuum diagram?-0996b43f8020e0bf.gif
Old Jun 8, 2012 | 11:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Problem understanding the vacuum diagram?
If this is a US car (not an export that was re-imported), then the carb diagram should be correct. As the EGR valve is under control of the ECM via the solenoid.
A car that was built without an ECM would use the other diagram.
RBob.
Old Jun 13, 2012 | 09:11 PM
vwdave's Avatar
Theyre not hard to understand. So Ill try to help out with the images you posted.
EGR solenoid is the same basic thing as a Thermostatic vacumn switch. One uses the ECU and the other uses coolant. Nothing special there, its just a check valve, one line to engine vacuum, one line to EGR.
Any other particular questions?
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mustangman65_79
Aug 8, 2015 12:07 PM
