Need help identifying a remanned factory ECM
Old Jul 26, 2012 | 06:52 PM
Untamed Z's Avatar
Trying to sort out tuning on this new project, and low and behold the ECM is remanned # 7-7165. Papers that I got with the car had a hypertech custom tuners worksheet included and show the ecm as 122 7727. Is the 7-7165 a remanned 122 7727? I was told by a prom burner that 122 7727 was speed density, but I think the car is currently MAF. Can someone please shed some light on this. The hypertech chip currently on the 7-7165 in the car is PN 7777.
Thanks in advance.
Old Jul 26, 2012 | 07:43 PM
utilityguy2's Avatar
Re: Need help identifying a remanned factory ECM
1227165 is a MAF ECM and 1227727 is a waterproof MAP ECM typically used in Corvettes and lots of other cars and under the hood. the Hypertech 7777 is for LT1 engines. everything you have posted is a mis-match.
Old Jul 26, 2012 | 08:24 PM
Untamed Z's Avatar
That's probably why the car has a bad tune. I did some research and think that I am going to do a custom MEMCAL for the 165 ECM. After researching, I am actually very surprised that the car even runs with the 7777 chip. Thanks for the help utilityguy.
Old Jul 26, 2012 | 08:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
if it is in fact a lt1 memcal if you remove the memcal cover lt1 92-93 memcals just have a knock board no other small chips under them.
Old Jul 27, 2012 | 08:42 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
A1 Cardone reman? they like to reuse the GM part numbers with a 7-xxxx with the x being the ladt 4 numbers in the ECM's original part number.
or at least i think it was A1 that did that...
anyways, it's a 1227165.
Old Jul 27, 2012 | 10:59 PM
Untamed Z's Avatar
Thank You all, I appreciate the help.
gta892000
Aug 11, 2019 11:16 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
gta892000
Sep 16, 2015 12:37 AM
