pocket programmer 2
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
pocket programmer 2
Any one use it, if so how do you program a SST 27SF512 chip
I select the SST 27SF512 chip in the program, erase it and
select my bin and program lt programs it, but when I put
it in my car the fans go on, so it's
in limp home mode. what am I doing wrong
Car: iroc z
Engine: 383 in the works
Axle/Gears: 3:73
Re: pocket programmer 2
did you double check your offset when you went to reprogram. I just did a few today
http://www.moates.net/manuals/FlashAndBurn.pdf
Car: iroc z
Axle/Gears: 3:73
if this is tpi $8d the offset for a 32k is buffer start 000000 -> 007FFF end chip start 008000 -> 00FFFF end.
Car: iroc z
Axle/Gears: 3:73
no the offset can be changed that is just a setting for the chip. If you put the information it the wrong address your car will go into limp home mode made that mistake today. lol
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
My pocket programmer2 has
buffer start
device start
device end
thats all what do I put in each line
buffer start
device start
device end
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Engine: Lb9
Transmission: M20
buffer start 000000
buffer end 007FFF
device start 008000
device end 00FFFF
buffer end 007FFF
device start 008000
device end 00FFFF
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Here is what pocket programmer web site had to say
To program a 27SF512 chip from a 27C256 file
select 27SF512
Set start of device to 8000
Load buffer with a 27C256 sized file (you can check the file size - right click on the file and select properties it should say 32K (32K*8 = 256K)
program chip
set start of device to 0000 so you don't screw up on your next chip.
If you have problems with this - please don't call us.
select 27SF512
program chip
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
64k what mask are you using ?
