ECM/PROM issues, no starting
Old Nov 18, 2012 | 03:16 PM
Marius's Avatar
Car: 1990 RS Vert
Engine: 305 TBI
Transmission: 5spd
Axle/Gears: Stock
I have spend the last few days on the search function and here I am.
History: Recently bought a 1990 camaro RS convert 305 TBI. Car ran, some idle issues, but now no start just cranks all day long, no fuel to the injectors (tested the pump 11PSI).
PO did a T5 swap, VATS bypass (Chip spliced into ECM Harness), and when I pulled the comp due to the strobing SES I found: ECM 1228062. Seems like its the wrong ECM, but PO gave me all the recipes for everything replaced on the car and so I just went to Advanced Auto to get a replacement since he ordered one almost a year ago. Calpack say 16051460. All my searching tells me that both are wrong for my engine, but the car was driven to my house 1.5 hour drive. What do I need to do? Seems I need a 1228746 ECM and have no Idea what PROM to get.
I'm all sorts of confused now!! Will the PROM and Calpack work with the new ECM (remanufactured) thats on order?
Old Nov 18, 2012 | 09:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM/PROM issues, no starting
The rapidly flashing SES is due to either a missing EPROM, or the wrong EPROM. An '8062 ECM isn't the right one for your car but it can run the engine OK. Just needs the proper PROM. The '8062 ECM is the truck equivalent to the '88 '8063 car (f & B body) ECM.
A '90 f-body should have the 1228746 ECM
With the rapidly flashing SES the ECM is in limp mode. Make sure that the smaller 16-pin DIP chip is in place. That is the limp calibration.
RBob.
Old Nov 18, 2012 | 10:46 PM
Marius's Avatar
Car: 1990 RS Vert
Engine: 305 TBI
Transmission: 5spd
Axle/Gears: Stock
Thanks RBob. The DIP is in. I hope a new ECM and replacing my PROM and Calpack will fix my no start issue.
Old Dec 2, 2012 | 07:33 AM
Marius's Avatar
Car: 1990 RS Vert
Engine: 305 TBI
Transmission: 5spd
Axle/Gears: Stock
So I finally got back to my project and I think I screwed up. I connected the battery before installing the ECM. I know thats wrong and the SES light still blinks. I think its the PROM since now I have the right ECM for my car, get fuel to the injectors, but car wont start.
Old Dec 2, 2012 | 10:29 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
what broadcast code do you have on the prom Antr , apty , axkw, antp,aptx ? code 51 form the mil ? The calpak will be stamped 16060837 but the part number is ac delco / gm 16060836.
Old Dec 2, 2012 | 11:51 AM
Engine: Lb9
Transmission: M20
I do have a few 16051637 ac delco 16051636 from 4.3,5.0,5.7,7.4 1227747 ecm that may work for lhm.
Old Dec 4, 2012 | 09:58 PM
Engine: Lb9
Transmission: M20
The best tune for the L03 manual trans is AXKW gm acdelco 16161123.
Old Dec 25, 2012 | 12:16 PM
Marius's Avatar
Car: 1990 RS Vert
Engine: 305 TBI
Transmission: 5spd
Axle/Gears: Stock
Just wanted to thank everyone for their help and all the TG.org peps for all their posts. My issue ended up being a fried ICM. If anyone in the CT/MA ever needs some help or whatever hit me up.
-Marius
Old Dec 25, 2012 | 02:14 PM
Engine: Lb9
Transmission: M20
Good deal getting the right ECM and prom that car will run nice finally .
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
