Old Nov 27, 2012 | 02:44 PM
brown200962's Avatar
HI;
Newbie question!
I am working on an engine swap using a 1986 Camaro 1227165 ECM. I am using a 1989 350 TPI engine and am having trouble with making a data connection using a aldl cable. I tried checking the pinouts as shown on the Chevythunder web site, and found that Serial data pin A8 shows "0" volts both key on and engine running.The Diagnostic Term pin A9 shows "0" volts key on and 4.97 volts engine running. Everything else checks out at or very near the voltages listed on the Chevythunder site. Does this mean my ECM is the problem? I can't seem to connect to the thing, and I have tried all the fixes that show up on the software (DataMaster,ALDLwindows and TunerPro RT websites.) I can get a connection using WinALDL but the stream of data shows the vehicle moving at ever changing speeds(on jack stands without driveshaft) and thats about all that comes across, the promid cells change right along with the MPH except a little box flashes red #6(WinALDL) that Jonas (WinALDL) was saying the MPG being sent out to the Corvette digital dashboard?? I am way over my head on this, the engine runs pretty well, but until I can find out what it is up to I can't do anything to smooth things out.
Dave Brown
Old Nov 27, 2012 | 02:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine Swap
winaldl requires a 10k resister across a to B this will raise the idle and disable the knock sensor. The box will change to green on winaldl and will update every 3 to 5 sec.
Old Nov 27, 2012 | 03:06 PM
Re: Engine Swap
Thanks for the reply, is the 10k resistor you are taklking about the one on the ALDL cable or one that I need to add? Thanks again!
Dave Brown
Old Nov 27, 2012 | 03:09 PM
Engine: Lb9
Transmission: M20
Re: Engine Swap
R3 is what I was referring to.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
