ECM QUESTION?????
Car: 1989 IROC Z28
Engine: 350 4 bolt main carbureted
Transmission: 700r4 w/ 3000 stahl
Axle/Gears: 2.73 posi
ECM QUESTION?????
I have a 1989 iroc-z with a tpi 305...i bought the car not running with intentions on dropping my built 350 in it...anyway the stock motor was so clean I tried to save it...so i noticed the engine light wouldnt come on when i turned the key forward so i knew it was a computer problem(replaced fuel pump also) I bought a reman NAPA computer(ECM) and the car fired up so I drove it and did a few burnouts...let it sit for a few days...and now the car wont start again and no engine light AGAIN....any ideas? i believe its a ground problem...but what ground? and what would be causing the computers to go bad on a stock car?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM QUESTION?????
It does sound like a ground issue if the check engine isn't lighting when the key is turned to the accessory position. The ecm grounds the check engine light when the key is turned on . The ground is the ecm's ground on pin d1,d3 and a12. I would think your fuel pump isn't doing the 2 second prime as well. The ecm and sensor grounds are located behind the passenger side cylinder head. You should check for constant 12v at the ecm pin B1 and c16 and with the key on the ecm switched power on pin a6.
Engine: Lb9
Transmission: M20
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Transmission: 5-speed/T-5
Yes, and if the ECM is functioning, but the PROM is bad the CEL would act EXACTLY as tunedperformanc said it would.
Lack of CEL at all is not an indication of bad PROM, it's an indication of a different problem than a PROM issue, lack of power or ground, or bad hardware.
Honestly, with the amount of time you post in these forums I would have thought that you would have learned a lot more about these systems than your posts lead on.
Axle/Gears: 3:42
:facepalm:
Axle/Gears: 3:42
With a bad prom the CEL could also go solid and stay that way.Also, in some cases the fans would run constantly and the car could ping. It could act like it was stuck in field service mode. Yes, his problem in this case could very well be bad grounds somewhere or a bad connection. Could be the main engine ground too.
READ THE FIRST POST There is no CEL being illuminated, none, no solid, no quick flash, nothing, so your post about bad PROM is just so far off the mark.
A bad PROM is so rare, that it is the last thing I look at, unless I get the CEL indication of a bad, or mis-seated PROM.
In this case the first things to check are the connects to and even at the ECM, along with related connectors and connects elsewhere. A good use of a DMM will have this problem licked in no time, without looking at things that are not the issue.
Axle/Gears: 3:42
It is part of the process of ruling things out. No one asked for YOUR opinion. You are new to this post. So if you can't post politely then YOU should not be a moderator on here. Our site doesn't need people like you on here.
Axle/Gears: 3:42
READ THIS: We are all trying to help each other on here, not create negative feelings or start arguments.
*sigh*
All you do is post incorrect information sending on wild goose chases looking for problems that don't exist.
I do believe information, or "input", that could be construed as an "opinion" was asked for by the OP, as to what his problem may be. Correcting inaccurate information posted by others is part of that.
Just because someone be be within the first few posts does not mean that they are posting correct information.
Please step away from the computer, and I will be able to post less, meaning I won't have to correct what you post so often.
In this case, what you already posted was of ZERO use to the OP, since the CEL was or is not illuminating at all, so your "easier check" is not, and in no way helps the OP.
Axle/Gears: 3:42
*sigh*
Axle/Gears: 3:42
*sigh*
*sigh*
I'm not the only one that sees your incorrect information.
The sad part is it's drop top roc's thread that you're mucking up with your defending of your incorrect, or misdirecting information.
You can go to JT all you want. Here's his contact info: https://www.thirdgen.org/forums/member.php?u=8676
You can continue to PM me all the threats you want, it's not going to change your habit of posting information that makes people go on wild goose chases looking for problems, or blatantly incorrect information.
You have two members now, tunedperformanc and myself telling you that what you're posting is not helpful and/or incorrect, in this thread alone. There have been many other threads where you've been told you're wrong and you respond in the same manner, with threads and e-**** swinging. I'm not about to stoop to your level of chest beating, all I will do is post the facts about the problem that a solution is being sought for.
I just hope that drop top roc is able to sort out the problem and posts back the results, to help others with a similar issue. The problem being discussed in this thread is an odd one, because it's intermittent, which will also make it harder to find.
Until he posts back with some results there's no reason to continue posting in this thread.
Axle/Gears: 3:42
*sigh*
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
No need to fight about who's correct and who's incorrect. That doesnt help the OP any at all. Just need to learn when to walk away. I'm in agreeance with six shooter. Since the OP replaced the ecm and the engine started and ran, that tells me the prom is just fine. Since it wont start anymore, I would look at the connections at the ecm since this was the only thing he messed with when he replaced the ecm. Probably has a bad pin fit in one of the connectors. Try wiggling the connectors or unplug them and plug them back in at the ecm and try starting again.
Axle/Gears: 3:42
Only thing is a bad prom is also intermittent at times. Also you are correct sometimes the connectors at the ECM connection can come loose and need to be pushed in or wiggled. I have seen that work before. I am not disagreeing with six shooter. I am making him aware of his rude comments.
Axle/Gears: 3:42
